Why is it uncommon to see rear V brake & Hydraulic front brake?
Sam Song
I was just wondering why I do not see this often on bikes since I just switched the rear hs33 to a v brake but kept the hope front disc brake.
And I just do not seem to see this combination that common on other people's bikes.
Any reasons?
right now I have v rear and cable disc front. Mainly because I can carry an extra brake cable if roadside repairs are needed. I have been debating on switching to HS33 to give them a try. so then ill have hs rear with a cable didc front
I will be trying HS33 just to give them a try. Never used them so I don't know what the differences are. Fiance got me a NOS 04 era Tomac HS33 Master cylinder and some slave cylinders. I gotta bleed them and give them a go. Ill use the same pad compound so it will be just determining the difference between v and Hydro
