Centering V brake arms
Sam Song
My v brake is set up, so that only one arm is moving and one of the pads is too close to the rim.
I am currently maxed out on the spring adjustment screws (the arm of the pad that is too close to the rim is at the tightest spring setting).
If I try to undo the spring tension screw on the other arm to move the pad out on the opposite side, then there is no tension on the cable at all, which leads me to believe that, the arm of the pad that is too close to the rim, might be sticky.
Anyways, it is so f**king frustrating right now and I feel like jumping off a bridge.
Set up:
Shimano Deore M590 arms, Odyssey Race Linear Cable, Avid SD7 lever.
