Brake Clamps - Which can be adjusted continuously?
JanStahl
Hi TF,
currently I run Magura HS11 slave cylinders using Magura clamps.
Because of the general TPA friction problem and huge temperature differences I face on my rides
I have the problem that I often need to adjust my slave cylinders in- or outwards.
However, I can do this only in steps of several millimeters, as the Magura plastic
rings want to fit into the grooves of the slave cylinder.
If I would now buy for example the Echo TR clamps for my HS11, would I be able to freely adjust the slave cylinder in its mean distance to the rim?
