PDF to WORD conversion
MikeCottTrials
I've done it with my uni work Mike?
What about printing it off, scanning and saving as different file type?
Nah man, it doesn't do a good enough job, in fact it makes a complete mess out of it.
I've found a work around for it, it's just going to be mega time consuming
Impossible just to print and hand write the stuff in?
Not impossible, just a whole lot less professional looking.
Got a solution for now guys! I'll post back and let you know if it comes to fruition
Yeah, it's so it can be read by a wider array of computers than if it was published as a word document...don't be a bell end
He's not being a bell-end, it's a serious point. People export to PDF so that they can't be edited in a lot of cases.
  • Like 1
I can't for the life of me remember which site I used last week to do this but they do exist. However, if it's just a case of filling in a few boxes you may have more joy just print screening and adding transparent text boxes as an overlay to keep it simple for now. Re-save as a PDF and they'll be none the wiser :P
Pretty much every PDF can be picked apart given the right software. The only way to really look down a PDF is to use rasterized artwork which is completely counter intuitive.
You can't expect word to just make a carbon copy of the PDF so you will have to copy and paste the respective text and images and place text boxes where relevant for the sections that'll need filling in later.
Alternatively like i've said use Adobe Acrobat which will write a word document out of your PDF. It is the industry standard and by far the best way to go about it.
