video file problem
Rebelistic
Can anyone help me with a video file problem?
I have some files off my camcorder (.MTS file extension). They were recorded at 50 fps. If I play them in windows media player they play ok. The problem is if I put them in my video editor (ulead video studio) when I export them they play at half speed (I assume because there are too many frames ie. playing a 50fps file at 25fps).
Does anyone know of a way I could convert them to 25fps files or any possible solution to my problem? Thanks :-)
As far as I understand, interlaced frames aren't complete frames, I think every other line of pixel is recorded and then in the next frame the missing lines - 1, 3, 5 first and then 2, 4, 6 second. The files run at a faster frame rate with potentially less blurring and it doesn't affect the filesize.
Deinterlacing I guess merges the extra frames so you get complete frames.
If interlacing reduces blur, if you deinterlace it you don't actually change the picture so the video should be just as crisp, just more compatible.
I've found a converter that makes the files into AVI files, then editor seems to handle these better. I don't know if they are interlaced or progressive?
I couldn't get my editor (ulead video studio) to be set for 50 fps files, I can see an option in the preferences but when I select it it doesn't have any other options only 25 fps. I should probably get a better editor but this has always been ok with 25 fps files.
What camera have you got? We might be able to tell you if its progressive or interlaced :)
It's a sony handycam HDR-CX130
Okay, according to this site: http://www.digitaltrends.com/camcorder-reviews/sony-hdr-cx130-review your camera can record in 1080 60 progressive.
"Also this camcorder captures 1080/60p video. In order to engage it, you have to adjust the frame rate in the menu system—it’s not under HD/SD quality which you would think would be the logical spot."
So I would guess that the footage you have is in fact progressive. However, I have had a look at how you can change the frame rate of your project in Ulead on Google but have had no luck.
Someone with some knowledge wanna step in? :P
Edited by streetrials24
