Anyone run their tyres the wrong way?
Dan_Trials
I'm sure this has been discussed before, I did search but couldn't find anything.
Just fitting a Minion on the rear wheel and looking at it I'd say it would be better for trials run against the suggested rotation due to the ramped and un-ramped edges on the tread blocks.
Just wondering if any one else had done this and what their findings were.
Ok thanks for the replies lads. Yeah I was aware that the direction arrows are for the tyre's original intended use - going fast over slippery terrain, but I looked on Tarty Bikes and saw that the bikes fitted with Maxxis tyres on the rear have the yellow Maxxis logo on the drive side, which would be as the suggested rotation. Then I figured this may be due to the person responsible for assembling the bike having to follow certain regulations.
I had just removed a High Roller funny enough. I guess you would find higher rolling resistance the wrong way due to it's design!
As a guy from a motorbike background ( if you wear your tyres backwards they get worn out 10x sooner) I am not sure if this thread is filled with a strange trick or with irony.
Yeah, Adam was trying to trick people into running them the wrong way so they'd wear out 10x sooner and people would buy more tyres. Gotta think of the £££'s.
  • Like 2
Ah to make me buy more tyres sooner? Nah, Adam once did him self out of a better sale to make sure I got the best part for my needs, top bloke!
Probably it is just me, that I spent too much time on motorbike forums, that I got suspicious of these things
I am aware that Adam does not want to trick anyone ( he helped me quite few times) but as a first read it is strange for me :)
Yeah but on a motorbike you probably manage hundreds of miles a week but my trials bike probably sees about ten miles a month
Bikes don't have Tyre damaging horsepower.
Most tyres are designed to have liw rolling resistance in the forward direction and loads of brake grip in the backwards direction,
Switch that round and you can often give better drive grip in loose conditions, but you loose grip in reverse, so it may loose grip when hanging of the edge of a wall or climing a steep rock.
That my theory ?
