Hope diaphragm.
UK_SPAWN
Hi all.
Just blead my front trial zone and after rolling on the diaphragm and tightening everything up I hear a small hiss and tiny bit of fluid in the small hole on the reservoir (breather hole?)
Is this normal?
The brake feels ok even with repeted pumping. Is this just air trapped above between the diaphragm and lid?
Thanks as allways.
Mark
post-35290-0-03149100-1371237365_thumb.j
This is where...
Thank you sir.
I did some more Googling and found a little bit more info on the diaphragm. A few people have said it's quite normal for a bit of fluid to show around the MC lid after a fresh bleed. I guess that hole is there for a reason :)
Another little thing is, on my other lever (mono trial) the reservoir bolts had been round off by whoever and I can't get them free with an allen key I was thinking;
Pliars around the side if the allen bolt but cant get grip. So...
Knock a slightly bigger key in.
Saw a slot into the bolt and use a flat head driver?
Which one seems the best idea? Or have any others?
Im going to order new bolts also (stan Ti probably)
Cheers again.
Thank you sir.
Cheers again.
Get some Torx Hex keys.
$T2eC16R,!zcE9s4g3I8)BRK6u9fb8Q~~60_12.J
Best bet for knocking into the rounded bolt. Sawing a slit is normally my last resort as the screw has broken on me in the past (More than once).
The above can slot into the groves where the old allen should sit aswell as forming new grooves for extra grip (Y)
