Sidehop tips
trialsiain
No not at all, rule I was told by Burkett is that when trying the highest you can possibly go you tweak it to front wheel, but when youre trying to make it look cool and comfortable you pop it up straight to two wheels.
If youre looking to get higher try pre loading more, and jumping up quicker and harder. In the world's of cls "kick hard reach high".
Also, practice makes perfect x
What George said really.
I LOVE sidehops, as you may have figured, and I almost always do them to two. Try tweaking your front wheel into the direction of the sidehop. Seems to help initiate the tuck which is a key part of really getting the max out of your move.
A friend of mine isn't to great at sidehops, he always tries them no matter what height but often slips down to chainstay.
This of course aggravates him more and more and he gets irritated when he can't do it. It's fairly clear that he only tries them so often because it's a move I do a lot when out riding, and I try and get him to do the same because I think he enjoys them like I do.
In reality he doesn't really enjoy them and only does them because I say he should, which is wrong of me as he doesn't like doing them. I'm obsessed with sidehops (sad I know) and that's why I do them so often and have spent so long getting the technique right, and spending ages looking at other styles of doing them. But not everybody is the same.
The point is don't listen to what anyone else says, do what makes you happy with your riding.
I used to do it to front wheel but i found it slowed my progress,
since i have learnt to go to two, side hops improve at a much faster rate (although i cant do them to front wheel anymore),
they feel and look a lot cleaner to both as well so i'd recommend that!
i learnt by taking my front brake off so i didnt have to rely on it
https://vimeo.com/50424281
This is from last summer
Edited by onza limey20
When jumping vertically, lean more backwards and trie to be as perpendicular to the floor as possible (as you can see you are sticking your head to the front. try not to do that). Then for the tuck, use more your legs than your arms. It must be a synchronized work.
I personally like to stand diagonally and a bit further to the obstacle, then you have more room to tuck.
myself;
myself;
You need to preload more
I think that depends on the effort of the sidehop, you won't preload the same in a low than a high wall :P
Well I'm just guessing that's one of your bigger side hops? So in that case you need to preload more
i'm stuck at bar height, i've got oodles of power but my brain just denies me any higher :( how do i proceed
Same here I think, not as much power as you though lol.
Keep trying sidehops slightly too big for you and you should start to get them bit by bit.
its just the way that you slip out from an under done one freaks me the f**k out, the bail doesn't feel controllable, maybe this is a lack of practice? i do avoid them...
I often miss the front end on them, I just put my foot out to the side as soon as I see/feel it miss, I've never really hurt myself that bad from them.
Pretty sure you're the same as me in that you land with your front pedal low and your back high ; when you fail a side hop your pedal can't catch you unlike most other people. Scares the shit out of me too haha
