HippY Posted June 13, 2013 Report Share Posted June 13, 2013 Hey guys I am planning to get a new brake, since 99% of the faults related to my bikes are happening because the worn brakes ( bought second hand). I have an option to buy an Echo TR brand new for 35 (full system). I did not hear anything about it so I ask for your help. any opinion or experience? anything I should pay attention? I am going to use them water and antifreezer bled, I have bad experiences with oil. Any special things about them? Quote Link to comment Share on other sites More sharing options...
isitafox Posted June 13, 2013 Report Share Posted June 13, 2013 Pretty certain a water bleed will leak in an echo, if it already has a good bleed then don't touch it! Quote Link to comment Share on other sites More sharing options...
HippY Posted June 13, 2013 Author Report Share Posted June 13, 2013 (edited) ohh, so I should get mineral oil in it anyway :/ I try to keep away oil if that would be possible, too expensive, and if it goes wrong, then my disc will die again Edited June 13, 2013 by UKHippY Quote Link to comment Share on other sites More sharing options...
Blake Posted June 13, 2013 Report Share Posted June 13, 2013 I've ran water in all my echo brakes, no problems. 1 Quote Link to comment Share on other sites More sharing options...
SCOTTY___ Posted June 14, 2013 Report Share Posted June 14, 2013 I bled mine with water. Pissed everywhere constantly. Complete bitch Quote Link to comment Share on other sites More sharing options...
HippY Posted June 14, 2013 Author Report Share Posted June 14, 2013 Alright just as a sums up what i heard - its shit bro -naah, its awesome, it will be good - water bleed is perfect - its baaaaad i just go more confused Quote Link to comment Share on other sites More sharing options...
tom@eastcoasttrials Posted June 14, 2013 Report Share Posted June 14, 2013 I ran water in my tr lever and it was fine all I found was it leaked at the bleed screw on the lever body bit of plummers white tape , (there is a proper name for it )but it worked fine with water Quote Link to comment Share on other sites More sharing options...
SCOTTY___ Posted June 14, 2013 Report Share Posted June 14, 2013 I ran water in my tr lever and it was fine all I found was it leaked at the bleed screw on the lever body bit of plummers white tape , (there is a proper name for it )but it worked fine with water PTFE Tape Quote Link to comment Share on other sites More sharing options...
tom@eastcoasttrials Posted June 14, 2013 Report Share Posted June 14, 2013 thats it plumbers tape for everything os what my ole man called it haha worked a treat though Quote Link to comment Share on other sites More sharing options...
bing Posted June 15, 2013 Report Share Posted June 15, 2013 If its an echo disk brake, leave it oil bled. I had one a while ago, and it was one of the best brakes I've ever had. Brutally powerful, it was bedded in perfect Quote Link to comment Share on other sites More sharing options...
UK_SPAWN Posted June 15, 2013 Report Share Posted June 15, 2013 My friends echodisk is rubbish...hmm I think its his pads or disk then... and you shouldn't water bleed any disk brake as the water will boil off and many other reasons. He also runs a rear tr lever/ "dengura" water blead, and its fine and doesn't leak. I think its how good you set them up and bleed them and what pads and disk you use that make more off a difference. I cant see a echo tr disk being any better or worse than any other. Cheers Quote Link to comment Share on other sites More sharing options...
HippY Posted June 19, 2013 Author Report Share Posted June 19, 2013 actually it will be the rim brake versions thanks for the help guys, i think i will go with them Quote Link to comment Share on other sites More sharing options...
stephenmx50 Posted June 19, 2013 Report Share Posted June 19, 2013 IMO most of the problems come from the slaves, the lever/piston are fine water bleed! Some problems caused from leaking from the lever are because the TPA is wound out to far past the sealing point. (check on tarty website for more info on this) I have a water bled echo TR rim brake up front with Maggy Slaves fitted, been on there for 2 years - not a single leak! Quote Link to comment Share on other sites More sharing options...
