Annoying Youtube problem when watching in full screen. Vid included
dann2707
Youtube does this weird thing when im in full screen, it brings the info and timeline back into view even if the mouse is untouched. The vid explains everything, might have to turn your monitor sideways but im sure you'll get it.
Anyone know of a fix? Cheers! Vid will be on in a seccy
On the topic of youtube problems, does anyone get the problem where if they click inside the video to do anything like pause it or change the volume or anything it gets, I guess stuck in the video? So if I push the down arrow to scroll down it will turn the volume down? I have to click outside the browser and back in to fix it.
Nobody else I know gets it but I use FF and no one else does...
Tried unplugging the mouse and seeing if it does it?
Optical mouse picking up a signal randomly? Some of ours at work would do that partly because of the surface they're on.
Never actually thought of that! Turned the mouse upside down and the problem is solved.
Thanks a lot :D
