CalRobbo341 Posted June 9, 2013 Report Share Posted June 9, 2013 I heard a rumor that its possible to run 20" forks on a 24" bike and if they are disc forks then you can use a disc. I'm guessing this depends on the tyre that you run, and maybe the pressure and things, but is it possible? I guess it might make the bike ride a little wired but I want to know your opinion? Cheeeers! And if it means anything, it would be a more TGS orientated frame with Trialtech 180+ Forks. Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted June 9, 2013 Report Share Posted June 9, 2013 it´ll lower the bb a fair bit(normal 24/26 forks are 395-425 a-c,20" around 350 afaik), and youll have to measure the inner length of the fork legs to the highest point under the crown. but why not? sometimes special setups work Quote Link to comment Share on other sites More sharing options...
SamKidney Posted June 9, 2013 Report Share Posted June 9, 2013 My 20" Urbans fit my 24" wheel while I was waiting for my 24" urbans to arrive. Never rode it that way though, was only so it could be rolled around when it needed moving. Quote Link to comment Share on other sites More sharing options...
Revolver Posted June 10, 2013 Report Share Posted June 10, 2013 It might actually make front wheel stuff easier. Quote Link to comment Share on other sites More sharing options...
dezmtber Posted June 11, 2013 Report Share Posted June 11, 2013 Mega for foot jams ? Quote Link to comment Share on other sites More sharing options...
isitafox Posted June 11, 2013 Report Share Posted June 11, 2013 Pretty sure there was a Russian guy who did it a few years back but had to shave his tyre down to get it to fit. Tried looking for the thread before but failed miserably. Would probably work with your old JAF Dez as it'd bring the bottom bracket down to a sensible height though you'd have to run a s**tload of spacers and a massive stem to make up the 40 odd mm height you lose up front Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted June 11, 2013 Report Share Posted June 11, 2013 that´d give the 100+ frame a purpose,finally! joking Quote Link to comment Share on other sites More sharing options...
dezmtber Posted June 12, 2013 Report Share Posted June 12, 2013 The +100 works much better on 410 forks with a 180mm stem. Quote Link to comment Share on other sites More sharing options...
Trialarn Posted June 15, 2013 Report Share Posted June 15, 2013 if its for footjams so would I prefer to use an brake booster! Quote Link to comment Share on other sites More sharing options...
