Rowlly21 Posted June 7, 2013 Report Share Posted June 7, 2013 Hi I am wanting to run snail cams on my onza pro but the frame is designed for chain tugs. Would drilling/Tapping holes in the drop out weaken it or do any damage ? Is this worth doing or not? Many thanks Andrew Quote Link to comment Share on other sites More sharing options...
clerictgm Posted June 7, 2013 Report Share Posted June 7, 2013 No, if you choose good place to drill and do all carefully. Quote Link to comment Share on other sites More sharing options...
bing Posted June 7, 2013 Report Share Posted June 7, 2013 I doubt it, its an early ish onza. They are solid as f**k Quote Link to comment Share on other sites More sharing options...
Blake Posted June 7, 2013 Report Share Posted June 7, 2013 If its a pro it probably has integrated tensioners meaning the spacing is different Quote Link to comment Share on other sites More sharing options...
Rowlly21 Posted June 7, 2013 Author Report Share Posted June 7, 2013 If its a pro it probably has integrated tensioners meaning the spacing is different It comes with Chain tugs? Quote Link to comment Share on other sites More sharing options...
bing Posted June 7, 2013 Report Share Posted June 7, 2013 Yeah should be ok Quote Link to comment Share on other sites More sharing options...
Rowlly21 Posted June 7, 2013 Author Report Share Posted June 7, 2013 Ok Thanks guys Andrew Quote Link to comment Share on other sites More sharing options...
