Modified Hope Pro 2 to 116mm spacing
trialsbikingnunn
I was attempting to poke fun at the posts I often see on here comparing CNC and cast stuff as if they're different processes, even though they're usually both used somewhere down the line.
Clearly I failed. :P
Anyway I'll try to be helpful instead, I'd doubt those marks are from the casting of the billet the hub shell was made from, as the rest of the hub shell has been machined and doesn't show any imperfections.
  • Like 1
looks more like lathe work to me
I filed the tab remnants down, and then used some wet and dry to get rid of any scoring.
A lathe was not used as there would have been no easy way to hold it in a chuck or collet without making up a jig.
ground off first then lathed I think.
You say you've used a lathe George?
Probably best to get the terminology right first...
#inb4haterzgunnahate
