tom@eastcoasttrials Posted May 21, 2013 Report Share Posted May 21, 2013 my front an rear maggies ive given them both a bleed and there still not feeting right and I cany seem to get a good oad set up at all what am i doing wrong Quote Link to comment Share on other sites More sharing options...
trialsiain Posted May 21, 2013 Report Share Posted May 21, 2013 do pads move straight away when you pull lever ? Quote Link to comment Share on other sites More sharing options...
stunt man t Posted May 21, 2013 Report Share Posted May 21, 2013 (edited) rebleed them again, they should work when there freshly bled, if not it could be your piston or your pads Edited May 21, 2013 by stunt man t Quote Link to comment Share on other sites More sharing options...
Jake. Posted May 21, 2013 Report Share Posted May 21, 2013 rebleed them again This. Make sure TPA is wound out too. Quote Link to comment Share on other sites More sharing options...
HippY Posted May 21, 2013 Report Share Posted May 21, 2013 ( I dont want to derail te topic, but I dont want to open a new topic with he same name twice) At my hs33 the piston is sticking. It is on pure water at the momen. should I add antifreezer ASAP? its an 04 version, and Tpa does not work, te ring spin with the tpa too. is tere any way to repair it? Quote Link to comment Share on other sites More sharing options...
