butterztrials123 Posted May 18, 2013 Report Share Posted May 18, 2013 I just changed from 24-18 to 18-12 on my onza bird. before i did this i asked about it on the forum. they said it would be harder to pedal. so i was surprised when it was easier to pedal. so could i have made a mistake or something? Quote Link to comment Share on other sites More sharing options...
bing Posted May 18, 2013 Report Share Posted May 18, 2013 No mate. 18-12 is perfect mod gearing. You'll find it loads easier to ride Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted May 19, 2013 Report Share Posted May 19, 2013 in theory it should make no difference,you´ve gone down 6 teeth on front and rear. but new drivetrain involves new bearings,maybe the old ones were knackered? Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted May 19, 2013 Report Share Posted May 19, 2013 It's the ratio of the teeth not the difference between the two numbers that dictates the gear ratio. If he went down 17 teeth... 18:12 is a harder gear than 24:18. Did you change anything else at the same time? Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted May 19, 2013 Report Share Posted May 19, 2013 youre right,adam. had to have a coffee to get it,posting without beeing fully awake haha 24:18=1.333333 18:12=1.5 with this wheelsize it makes a difference really 1 Quote Link to comment Share on other sites More sharing options...
CC12345678910 Posted May 21, 2013 Report Share Posted May 21, 2013 Forgive me for asking this (cos I have seen photographic proof of someone doing this) but you have put the 18t on the crank haven't you? What else did you replace exactly? Could higher EP give you impression stuff is lighter to crank around? Quote Link to comment Share on other sites More sharing options...
ben_travis Posted May 21, 2013 Report Share Posted May 21, 2013 while i doubt it, i would love if it came to be that he'd actually started running 12-18. That'd be amazingly funny while also feeling bad for the guy. 4 Quote Link to comment Share on other sites More sharing options...
CC12345678910 Posted May 22, 2013 Report Share Posted May 22, 2013 Ben as I said, I've seen photos of someone doing this... To the OP. Please don't be offended by such posts... With the amount of information and description you gave, it's a 'just checking' kinda post. Cos I gotta wonder what has happened? You changed from a newbie bike standard done for cost reasons, to a standard every mod worth it's salt is sold with when new. And yet you say it feels worse? Quote Link to comment Share on other sites More sharing options...
butterztrials123 Posted May 22, 2013 Author Report Share Posted May 22, 2013 I put the freewheel from the wheel straight to the crank and put a 12 sprocket on the wheel, nothing else Quote Link to comment Share on other sites More sharing options...
Ben Cox Posted May 23, 2013 Report Share Posted May 23, 2013 This may sound silly. But are you sure its an 18 not a 16? As that would make it feel quite light and a bit poo. Ben Quote Link to comment Share on other sites More sharing options...
williams Posted May 23, 2013 Report Share Posted May 23, 2013 Orrrrr, you're not just used to it yet. Eitherway, 18-12 is the best gear ratio for a mod Quote Link to comment Share on other sites More sharing options...
cardenas_26trials Posted May 24, 2013 Report Share Posted May 24, 2013 Maybe he also changed pedals? lighter pedals can make it feel different Quote Link to comment Share on other sites More sharing options...
Ben Cox Posted May 24, 2013 Report Share Posted May 24, 2013 Or longer cranks make it feel lighter. Ben Quote Link to comment Share on other sites More sharing options...
dezmtber Posted May 25, 2013 Report Share Posted May 25, 2013 Wow I am gonna go buy some lighter pedals right away 1 Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted May 25, 2013 Report Share Posted May 25, 2013 Or longer cranks make it feel lighter. Ben 1) Check you're definitely running 18:12. Count the teeth... 2) Shorter cranks will make the gear ratio feel 'harder'. So changing to 18:12 AND putting shorter cranks on will feel REALLY hard 3) If you've changed your pedals, that will make a difference too I guess, but that would be obvious 4) Make sure your chain is lubed up too If all youve done is as you say, 18t freewheel on cranks and 12t on rear and its still too stiff then you have two choices. Suck it up (in a nice way), its pretty much a standard and might improve your riding, OR change the rear to a 13t sprocket. Mr Read ran one a while ago on a silver monty 221ti (memory like an elephant ) to give it a light feeling. Doing this though will lower your 'top speed' and might mean you dont get the most out of your pedal kicks.... Quote Link to comment Share on other sites More sharing options...
butterztrials123 Posted May 27, 2013 Author Report Share Posted May 27, 2013 It's defiantly 18-12 and I think the cranks are either 160 or165 Quote Link to comment Share on other sites More sharing options...
Jake. Posted May 27, 2013 Report Share Posted May 27, 2013 Got a picture of the setup? Quote Link to comment Share on other sites More sharing options...
butterztrials123 Posted May 27, 2013 Author Report Share Posted May 27, 2013 No but it doesn't matter at the moment because my freewheel broke after just 4days on the cranks and I don't know why Quote Link to comment Share on other sites More sharing options...
isitafox Posted May 27, 2013 Report Share Posted May 27, 2013 Chain too tight 1 Quote Link to comment Share on other sites More sharing options...
