josh pollard Posted May 18, 2013 Report Share Posted May 18, 2013 Need something that will definatley make my grips stick. I have tried hairspray and even glue but eventually they both ware off. Any ideas on what i can use? Quote Link to comment Share on other sites More sharing options...
CalopS Posted May 18, 2013 Report Share Posted May 18, 2013 Which grips? I put my TT standard sized grips on with a track pump with nothing on the bar and they have been solid Quote Link to comment Share on other sites More sharing options...
SamKidney Posted May 18, 2013 Report Share Posted May 18, 2013 He's using TT foams on Carbon bars I think. Quote Link to comment Share on other sites More sharing options...
josh pollard Posted May 18, 2013 Author Report Share Posted May 18, 2013 Yeah, TT foams on Carbon bars. Quote Link to comment Share on other sites More sharing options...
Revolver Posted May 18, 2013 Report Share Posted May 18, 2013 Clear lacquer? Quote Link to comment Share on other sites More sharing options...
josh pollard Posted May 18, 2013 Author Report Share Posted May 18, 2013 hmm, i could try that i guess. Quote Link to comment Share on other sites More sharing options...
isitafox Posted May 18, 2013 Report Share Posted May 18, 2013 Put a single run of electrical tape on first to increase the diameter of the bars then slide them on with some cable ties Quote Link to comment Share on other sites More sharing options...
josh pollard Posted May 18, 2013 Author Report Share Posted May 18, 2013 Yeah, ill try that. Thanks, ill let you know if it works. Quote Link to comment Share on other sites More sharing options...
p_ruskin Posted May 18, 2013 Report Share Posted May 18, 2013 Lacquer or black spray paint, they properly stick them on, you just have to be quick sliding them on as it dries really fast Quote Link to comment Share on other sites More sharing options...
Sam Moss Posted May 18, 2013 Report Share Posted May 18, 2013 just put some tar on 1 Quote Link to comment Share on other sites More sharing options...
UK_SPAWN Posted May 19, 2013 Report Share Posted May 19, 2013 I found anything u put on usualy wears off/moves. Clean bars n grips (inside) with pure warm water, let them dry properly. Put grips on, bar end plugs and a tie wrap each end pulled tight with pliars. Jobs a good en' Quote Link to comment Share on other sites More sharing options...
jack1340 Posted May 19, 2013 Report Share Posted May 19, 2013 I used hair gel then dried it with a hairdryer... We all used to do it on our bmx and it worked well Quote Link to comment Share on other sites More sharing options...
