TrashZen Posted May 17, 2013 Report Share Posted May 17, 2013 (edited) Yep, I finally opted for a GU: Pimp ride, I tried out various chainstay lengths by tweaking the half-link chain, and finally opted for a 378mm chainstay (that definitely feel very sharp and reactive on the rear wheel). You can check out the full specs Here I don't have a scale precise enough to give a weight. Edited May 17, 2013 by TrashZen Quote Link to comment Share on other sites More sharing options...
chimpanzyyyy Posted May 17, 2013 Report Share Posted May 17, 2013 hi julien bike looks lush better than the old one IMO keep an eye on that chain when you practice those drop gaps! seems every halflink chains has a bad reputation for snaping Quote Link to comment Share on other sites More sharing options...
SamKidney Posted May 17, 2013 Report Share Posted May 17, 2013 You're a braver man than I opting for a half link. I'd run a normal chain and sacrifice a few mm on your final cs length than run that. Looks swish though. Quote Link to comment Share on other sites More sharing options...
Mark W Posted May 17, 2013 Report Share Posted May 17, 2013 A regular link chain would end up in the same point - using 18:15 and a normal chain it sits at roughly 380mm, so a half link would change that by quite a lot, not just the 2mm you've mentioned there. Similarly, the brake mounts were positioned to work with a full-link chain at 18:15 so I'd imagine a half-link would mess that up a bit. It might be worth counting the links you're using, and if it's an even number just putting a normal chain on - I've only ever had bad experiences with half-link chains, so if you're not getting the benefit of being half way between positions a normal chain would be in, it just seems like a heavier, weaker chain for no reason. That aside, the bike looks cool Quote Link to comment Share on other sites More sharing options...
bing Posted May 17, 2013 Report Share Posted May 17, 2013 Looks nice dude, aside from the seriously dodgy chain Quote Link to comment Share on other sites More sharing options...
TrashZen Posted May 17, 2013 Author Report Share Posted May 17, 2013 (edited) On 5/17/2013 at 6:10 PM, Mark W said: A regular link chain would end up in the same point - using 18:15 and a normal chain it sits at roughly 380mm, so a half link would change that by quite a lot, not just the 2mm you've mentioned there. Similarly, the brake mounts were positioned to work with a full-link chain at 18:15 so I'd imagine a half-link would mess that up a bit. It might be worth counting the links you're using, and if it's an even number just putting a normal chain on - I've only ever had bad experiences with half-link chains, so if you're not getting the benefit of being half way between positions a normal chain would be in, it just seems like a heavier, weaker chain for no reason. That aside, the bike looks cool Yes, in fact, I first used my old chain, it was roughly at the same spot, but then the rear tyre is was really feathering the yoke, like is has 2mm left, and I thought I would add half a link to space it up (and then the brake mounts were a bit on the fringe and also, I felt the bike was less reactive) So I reverted to the same chain length (removing a half-link). It is a 1/8"gusset, typically used for BMXs. Supposed to be solid. :'( Edited May 17, 2013 by TrashZen Quote Link to comment Share on other sites More sharing options...
chimpanzyyyy Posted May 17, 2013 Report Share Posted May 17, 2013 On 5/17/2013 at 6:28 PM, TrashZen said: It is a 1/8"gusset, typically used for BMXs. Supposed to be solid. :'( not for trials riding use I m afraid Quote Link to comment Share on other sites More sharing options...
Mark W Posted May 17, 2013 Report Share Posted May 17, 2013 Not even for BMX use really, haha. Quote Link to comment Share on other sites More sharing options...
Canardweb Posted May 18, 2013 Report Share Posted May 18, 2013 Remove that death-chain right now! Or get a fidelity card by your local dentist... Quote Link to comment Share on other sites More sharing options...
TrashZen Posted May 18, 2013 Author Report Share Posted May 18, 2013 On 5/18/2013 at 9:23 AM, Canardweb said: Remove that death-chain right now! Or get a fidelity card by your local dentist... Whoaaa!!! That's a bit harsh innit? Well, I'll consider it... You lots are getting me scared now... I usually keep my chains for a couple of years, that's when they start breaking into bits... I'll keep you updated. Quote Link to comment Share on other sites More sharing options...
Canardweb Posted May 18, 2013 Report Share Posted May 18, 2013 On 5/18/2013 at 7:35 PM, TrashZen said: Whoaaa!!! That's a bit harsh innit? Well, I'll consider it... You lots are getting me scared now... I usually keep my chains for a couple of years, that's when they start breaking into bits... I'll keep you updated. Because I really don't want what happened to one of my friend to happen to you. Quote Link to comment Share on other sites More sharing options...
kaarel Posted May 20, 2013 Report Share Posted May 20, 2013 On 5/18/2013 at 7:35 PM, TrashZen said: Whoaaa!!! That's a bit harsh innit? Well, I'll consider it... You lots are getting me scared now... I usually keep my chains for a couple of years, that's when they start breaking into bits... I'll keep you updated. Get KMC Z510 HX and change it every season or if possible then even more frequently, then you'll be all right! BTW Epic bike, would ride! Quote Link to comment Share on other sites More sharing options...
Maxx Posted May 20, 2013 Report Share Posted May 20, 2013 On 5/18/2013 at 7:35 PM, TrashZen said: I usually keep my chains for a couple of years You're crazy Quote Link to comment Share on other sites More sharing options...
TrashZen Posted May 20, 2013 Author Report Share Posted May 20, 2013 On 5/20/2013 at 9:15 AM, Maxx said: You're crazy I 've got a fairly simple policy of not changing parts until they break... but hey... I'll see how this chain goes.. (A) Quote Link to comment Share on other sites More sharing options...
Maxx Posted May 20, 2013 Report Share Posted May 20, 2013 On 5/20/2013 at 12:22 PM, TrashZen said: I 've got a fairly simple policy of not changing parts until they break... but hey... I'll see how this chain goes.. (A) I agree for some parts only. A chain has to be a secure element. It's not like a wheel which breaks. Two months ago I broke my nose on a transfert because of a chain snap. The chain (KMC Z610HX) was only 3 months old and didn't have any hits as far I'm aware (and I know how to correctly mount a chain) Quote Link to comment Share on other sites More sharing options...
Revolver Posted May 20, 2013 Report Share Posted May 20, 2013 It's weird how chains snap loads for some people and never for others. I almost never snap chains. 1 Quote Link to comment Share on other sites More sharing options...
3dd Posted May 20, 2013 Report Share Posted May 20, 2013 Nice build! I have only snapped one half link chain in my life, that was more than enough! Quote Link to comment Share on other sites More sharing options...
