p_ruskin Posted May 16, 2013 Report Share Posted May 16, 2013 In need of a new kit, If i want tap out to M6 and insert back to M5 which size kit do i need? The sizing system has confused me slightly, is an M6x1.0 kit and M6/insert that will take an M5 bolt? Or do i need the M5x0.8 kit to repair/replace M5 threads? Cheers Quote Link to comment Share on other sites More sharing options...
bing Posted May 16, 2013 Report Share Posted May 16, 2013 (edited) M6x1.0 to repair and use m6 threads, uses a 6mm drill bit M5x0.8 to repair and use m5 threads, uses a 5mm drill bit This is because the insert is physically bigger than 5mm, and the thread cutting tap needs some material to cut into, so the coil can be wound in and be made secure If you want to keep the m5 threads, providing there is enough material left on the frame and its not completely wrecked, use an m5 kit. Otherwise its a drill out job and use the m6 kit, and then you will have to get your clamps modified to suit Edited May 16, 2013 by bing Quote Link to comment Share on other sites More sharing options...
p_ruskin Posted May 16, 2013 Author Report Share Posted May 16, 2013 Thats just what i was after, cheers man Quote Link to comment Share on other sites More sharing options...
bing Posted May 16, 2013 Report Share Posted May 16, 2013 Just edited it dude, more info Quote Link to comment Share on other sites More sharing options...
p_ruskin Posted May 16, 2013 Author Report Share Posted May 16, 2013 Yeah there is plenty of spare material on there, still hoping to run M5 bolts so the M5x0.8 kit comes with a M6 tap and the inserts take it back down to the M5 size? Quote Link to comment Share on other sites More sharing options...
bing Posted May 16, 2013 Report Share Posted May 16, 2013 (edited) No, its a specific helicoil tap, its bigger than 5mm but its 0.8mm pitch, this is so when the coil is wound in, its the correct dimensions, and gives you a good strong thread. In many cases, the helicoil is stronger than the material to start with. You will still be able to use the m5 bolts with this kit, and it should be quite strong, this is a typical kit Edited May 16, 2013 by bing Quote Link to comment Share on other sites More sharing options...
p_ruskin Posted May 16, 2013 Author Report Share Posted May 16, 2013 Yeah i had one previously but the tap broke and i ran out of inserts, i didn't know what exact set it was though so i couldn't get a replacement tap for the particular inserts cheers mate Quote Link to comment Share on other sites More sharing options...
bing Posted May 16, 2013 Report Share Posted May 16, 2013 Its an m5 helicoil tap. There's loads on ebay Quote Link to comment Share on other sites More sharing options...
