Lrn2Trial Posted May 7, 2013 Report Share Posted May 7, 2013 Come home the other day and found that my nephew had been on my bike and the pedal was loose but he didn't tighten it up he kept riding ! So I when I got on it and cycled I realised he stripped all the thread from the pedal end of the crank. So Iv'e bought try all Isis cranks for a replacement Quote Link to comment Share on other sites More sharing options...
Blake Posted May 7, 2013 Report Share Posted May 7, 2013 Cray 1 Quote Link to comment Share on other sites More sharing options...
dann2707 Posted May 7, 2013 Report Share Posted May 7, 2013 Nightmare. Could you get them re-tapped? Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted May 7, 2013 Report Share Posted May 7, 2013 helicoil! Quote Link to comment Share on other sites More sharing options...
Blake Posted May 7, 2013 Report Share Posted May 7, 2013 ye tarty do a service Quote Link to comment Share on other sites More sharing options...
Lrn2Trial Posted May 7, 2013 Author Report Share Posted May 7, 2013 (edited) If they do will the pedals still fit in ? Because now they can slide in and out because so much thread has been stripped. Edited May 7, 2013 by Lrn2Trial Quote Link to comment Share on other sites More sharing options...
dezmtber Posted May 7, 2013 Report Share Posted May 7, 2013 Fit a tensile crank insert Quote Link to comment Share on other sites More sharing options...
alecwray Posted May 7, 2013 Report Share Posted May 7, 2013 You can repair these seen a few people do it after the same thing Quote Link to comment Share on other sites More sharing options...
CalopS Posted May 7, 2013 Report Share Posted May 7, 2013 Sell your nephew to cover the cost of new cranks and check your pedals regularly to make sure they are tight! 4 Quote Link to comment Share on other sites More sharing options...
Lrn2Trial Posted May 7, 2013 Author Report Share Posted May 7, 2013 Should have done some research before buying new cranks, I was so close to buying the echo SL 2013, But decided to wait untill I get better. Quote Link to comment Share on other sites More sharing options...
chimpanzyyyy Posted May 8, 2013 Report Share Posted May 8, 2013 did you remove your pedal with easy after this? I have a similar issue at the moment, and my pedal is stuck keep turning in both directions but can't get it off I was thinkin about cutting the crank with the angle grinder to have my pedal back Quote Link to comment Share on other sites More sharing options...
ooo Posted May 8, 2013 Report Share Posted May 8, 2013 I had my trialtechs helicoiled and it lasted about an hour, I guess it works for other people. From my experience I think new cranks is cheaper in the long run, so don't worry about buying them. 1 Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted May 8, 2013 Report Share Posted May 8, 2013 I had my trialtechs helicoiled and it lasted about an hour You still need to keep the pedals tight as if the cranks were new (very frequently), because it's a brand new thread... Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted May 8, 2013 Report Share Posted May 8, 2013 (edited) http://www.google.de/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&cad=rja&ved=0CHIQFjAF&url=http%3A%2F%2Fwww.uniortools.com%2Fcgi-bin%2Fcms.cgi%3Fdoc%3D10780%26prod%3D44810%26sid%3DE9vUIYXEzT861Fyz&ei=w0SKUfuSFe-g7AacqoCwDA&usg=AFQjCNGOW4WevGMW4LdRZouJzuRbthFpfw&sig2=l8xOqVYSK6TT5WicW_ed4g&bvm=bv.46226182,d.ZGU we use those at work and even downhillers didnt get them to get ripped out again... little trick is to insert the pedal a bit(prevents the insert from deforming at the next step),take a center punch and knock 2 little holes opposite to each other between the insert and the crank material,then turn the pedal out again a bit,then tighten it. with that it can unscrew itself never ever again... Edited May 8, 2013 by FamilyBiker Quote Link to comment Share on other sites More sharing options...
Lewis Gething Posted May 8, 2013 Report Share Posted May 8, 2013 I had my Trialtech cranks helicoiled by Tarty and they were good as new, never had any problems after they were fixed, never even a hint of coming loose Quote Link to comment Share on other sites More sharing options...
dave33 Posted May 8, 2013 Report Share Posted May 8, 2013 Helicoils are fine if they are fitted correctly, the hole needs to be the correct size for the tap to achieve 100% thread depth. It's difficult to dril the correct size hole with a cordless drill for example. Althought if used in alloy they can be alot stronger than the original thread the fixing must be kept at the required preload to avoid damage and failure. So not reply the correct application for a pedal which is going to be removed now and again. Your much better off with a solid incert like the 'time cert' style which can be glued inplace. They are also better for a high tourque situation when the bolt or fixing will start to stretch which is when the Helicoil can fail. If you pedal can be pulled out the hole might be to large, in Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted May 8, 2013 Report Share Posted May 8, 2013 ^^ Yep. Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted May 8, 2013 Report Share Posted May 8, 2013 +1 for the timesert.i first said helicoil,then realized i´m using unior at work,theyre exactly like timeserts Quote Link to comment Share on other sites More sharing options...
Lrn2Trial Posted May 8, 2013 Author Report Share Posted May 8, 2013 did you remove your pedal with easy after this? I have a similar issue at the moment, and my pedal is stuck keep turning in both directions but can't get it off I was thinkin about cutting the crank with the angle grinder to have my pedal back No my pedal did not come out easily I had to just keep turning the Allen key until the pedal released, The thread on my pedal was still in perfect condition but the thread on the crank was stripped completely. Quote Link to comment Share on other sites More sharing options...
chimpanzyyyy Posted May 9, 2013 Report Share Posted May 9, 2013 No my pedal did not come out easily I had to just keep turning the Allen key until the pedal released, The thread on my pedal was still in perfect condition but the thread on the crank was stripped completely. that was'nt working, so I cut the crank open with an angle grinder bye bye crank but the pedal is fine Quote Link to comment Share on other sites More sharing options...
Lrn2Trial Posted May 9, 2013 Author Report Share Posted May 9, 2013 that was'nt working, so I cut the crank open with an angle grinder bye bye crank but the pedal is fine Ye my pedal was fine after I removed my with force too I think the pedal thread is steel and the cranks aluminium. But I've fitted Try-All cranks now that are 160mm and my old Trialtech ones were 165mm I'm not 100% sure but I think I can feel a difference or maybe it's because I haven't been on my bike for a few days. So I recommend if you get new ones get the same size. Quote Link to comment Share on other sites More sharing options...
chimpanzyyyy Posted May 9, 2013 Report Share Posted May 9, 2013 Ye my pedal was fine after I removed my with force too I think the pedal thread is steel and the cranks aluminium. But I've fitted Try-All cranks now that are 160mm and my old Trialtech ones were 165mm I'm not 100% sure but I think I can feel a difference or maybe it's because I haven't been on my bike for a few days. So I recommend if you get new ones get the same size. yeah, I think the one I have in stock isn't the same size either but it will do the trick untill I bought a new pair Quote Link to comment Share on other sites More sharing options...
dave33 Posted May 9, 2013 Report Share Posted May 9, 2013 yeah, I think the one I have in stock isn't the same size either but it will do the trick untill I bought a new pair Do you mean you going to ride with two different length cranks ? Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted May 9, 2013 Report Share Posted May 9, 2013 its alright,just wear a buffalo plateau boot on the side with the shorter crank. Quote Link to comment Share on other sites More sharing options...
chimpanzyyyy Posted May 9, 2013 Report Share Posted May 9, 2013 Do you mean you going to ride with two different length cranks ? dunno for sure first thing first but if I don't have any other option when the sun is shining and I have a urge to ride then I ll do that untill I order a new pair is it that awefull? Quote Link to comment Share on other sites More sharing options...
