front disc cleaning
ashleys sugden
Hi guys, this morning i ripped my hose off my front echo disc brake trying footjam whip thingys. oil went all over the disc and the pads. ive fixed all the fittings and re-bled the brake, but its still sh*t, i wire brushed the pads to remove the oil and i washed the disc in hot water. ive tryed bedding it in again by spraying water on it after using the brake for a while. it stays good for about 5 minutes but then goes bad again.
any help? thanks
Edited by ashleys sugden
I've tried everything to sort contaminated pads in the past, including burning the oil out of them with a blow torch. Nothing seemed to work, it was always just easier to replace them.
Yea I agree better off with new pads. But blow torch never really gets them hot enough, I was putting them in the oven at 200 degrees c
Orly, I assumed a blow torch would be way hotter than 200C? I've had resin running out of the pads before with a blow torch so didn't want to get it any hotter.
Yes I agree, it does depend how long you hold it on them.
Once they star going dark/red I think that's about 550c
Cherry red is about 800//900 for steel
ill give that a go actually, someone told me to do this to my moto trials a few years back, cheers man
I put some on my rim years ago, around the time of monty brake spray. Worked abit to good lol
