onza pro series guy Posted May 2, 2013 Report Share Posted May 2, 2013 Hi guys, pretty much as the title says, I'm looking for advice on how to get the brake runs and mounts off my inspired frame and forks. Shall I attack them with a hacksaw and play it safe or will that take forever and i should grab a grinder and a cutting disc? Anybody done it? what method did you use? thanks fellas Dave Quote Link to comment Share on other sites More sharing options...
clerictgm Posted May 2, 2013 Report Share Posted May 2, 2013 Use hammer, screwdriver and force. Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted May 2, 2013 Report Share Posted May 2, 2013 Use hammer, screwdriver and force. 2 Quote Link to comment Share on other sites More sharing options...
JD™ Posted May 2, 2013 Report Share Posted May 2, 2013 He's not particularly far off the mark - I used a chisel and hammer on one of the cable guides on the Zoot frame I did, just to see whether it'd work. It did. The others I played it safe though, I used a dremel and then a file, and then sandpaper. Here's a photo album of the progress that might help. Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted May 2, 2013 Report Share Posted May 2, 2013 did the cable lugs on my limey recently. I did it with a file and it took ages, but how i would do it is: get the worst off with a grinder tidy it up with a file wet and dry until its perfect Quote Link to comment Share on other sites More sharing options...
isitafox Posted May 2, 2013 Report Share Posted May 2, 2013 Doing the same with my fourplay, is a nightmare! Hacksaw then file. Quote Link to comment Share on other sites More sharing options...
onza pro series guy Posted May 2, 2013 Author Report Share Posted May 2, 2013 Alright so i'm thinking im gonna get to the runs with a hacksaw and file and then grinding the actual mounts seeing as I don't have a dremel, or is it worth asking around my mates to see if i can get my hands on a dremel? 1 Quote Link to comment Share on other sites More sharing options...
isitafox Posted May 2, 2013 Report Share Posted May 2, 2013 Just use a hacksaw on the mounts Quote Link to comment Share on other sites More sharing options...
onza pro series guy Posted May 13, 2013 Author Report Share Posted May 13, 2013 Been making some progress Quote Link to comment Share on other sites More sharing options...
