First Full Face
1337 Trials
CRC is good because its free to send back if it doesn't fit. It can take a fair bit of looking around to find a good fit, depending on your head shape.
Make sure you get a good fit even if it costs you more.
winstanleysbikes.co.uk is usually pretty cheap on helmets too though.
different companies work from different ergonomic data, i.e. a 57cm helmet from met is not the same shape as a 57cm helmet from giro etc.
go to a shop, try a few on, find a brand that fits well, then order it online for half the price.
trust me, worth it
Ive got that helmet. Its very basic, but i found it fit me better than the next model up. You really should try them out, its not all about head size. I found the jaw pads on the other model gave me jaw ache after a few minutes, where as the jaw padding is wider on this one.
Just received the helmet. It looks like it has been badly treated by the post men. Theres a plastic piece that goes on the mouth and it has been smashed off and the holes to bolt it back on have been snapped off.
The helmet fits ok. Feels a little tight on the chicks but should I let it bed in?
