bike_dummie Posted April 24, 2013 Report Share Posted April 24, 2013 Hi, Recently switched to Magura due to the echo 24 frames not having as disc mount but it keeps on slipping? I don't really know much about Maguras so any tips on stopping this would be great My set up is Echo 24 Echo 7075 clapms (filed down so they are washerless) Echo Sl lever body with piston ect Magura fittings and hoses ADM pads TrialTech Carbon Booster Neon rim Thanks Adam Quote Link to comment Share on other sites More sharing options...
Blake Posted April 24, 2013 Report Share Posted April 24, 2013 you mean it slips when you're on back wheel? like it doesn't hold or does it move in the clamps? Quote Link to comment Share on other sites More sharing options...
bike_dummie Posted April 24, 2013 Author Report Share Posted April 24, 2013 you mean it slips when you're on back wheel? like it doesn't hold or does it move in the clamps? It wont hold when im on the back wheel The clamps themselves are fine Quote Link to comment Share on other sites More sharing options...
Blake Posted April 24, 2013 Report Share Posted April 24, 2013 Tar or a good grind, or a rim free of grease Quote Link to comment Share on other sites More sharing options...
bike_dummie Posted April 24, 2013 Author Report Share Posted April 24, 2013 Maybe i will give it another grind this one is only a week old though ! Quote Link to comment Share on other sites More sharing options...
alistair14 Posted April 24, 2013 Report Share Posted April 24, 2013 Tar or a good grind, or a rim free of grease No tar. Maybe i will give it another grind this one is only a week old though ! Ill grind it for you dude, your grind wasn't the best to be honest! Quote Link to comment Share on other sites More sharing options...
Blake Posted April 24, 2013 Report Share Posted April 24, 2013 TAR Quote Link to comment Share on other sites More sharing options...
fbmbmx Posted April 25, 2013 Report Share Posted April 25, 2013 Both? Quote Link to comment Share on other sites More sharing options...
Jake. Posted April 25, 2013 Report Share Posted April 25, 2013 (edited) Are you sure you gave it a proper grind? Don't put tar on a grind if you can avoid it, it rolls into the grind and smooths it out. Edited April 25, 2013 by JMCD Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted April 25, 2013 Report Share Posted April 25, 2013 Take the booster off. Sometimes a bit of flex is a good thing. Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted April 25, 2013 Report Share Posted April 25, 2013 it isnt a disc brake, you have to pull the lever hard 1 Quote Link to comment Share on other sites More sharing options...
N.Wood Posted April 25, 2013 Report Share Posted April 25, 2013 Take the booster off. Sometimes a bit of flex is a good thing. Booster increases hold. 1 Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted April 25, 2013 Report Share Posted April 25, 2013 Booster increases hold. In past experience, on my Echo 24" with TNN ADM Pads, Echo Clamps and a Neon Rim the booster made it worse. I'm sure i'm in a position to tell him how to make it better seeing as i came from the same set up. I can try and find a picture if you don't believe me? Quote Link to comment Share on other sites More sharing options...
Revolver Posted April 25, 2013 Report Share Posted April 25, 2013 Not sure how a picture can demonstrate how much hold a brake setup gives. Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted April 25, 2013 Report Share Posted April 25, 2013 In past experience, on my Echo 24" with TNN ADM Pads, Echo Clamps and a Neon Rim the booster made it worse. I'm sure i'm in a position to tell him how to make it better seeing as i came from the same set up. I can try and find a picture if you don't believe me? Not sure how a picture can demonstrate how much hold a brake setup gives. Obviously i was talking about a picture of the set up. Quote Link to comment Share on other sites More sharing options...
N.Wood Posted April 25, 2013 Report Share Posted April 25, 2013 In past experience, on my Echo 24" with TNN ADM Pads, Echo Clamps and a Neon Rim the booster made it worse. I'm sure i'm in a position to tell him how to make it better seeing as i came from the same set up. I can try and find a picture if you don't believe me? I'm sure you are. I'm just sayin' a booster will increase hold but DECREASE bite. So agreed, will 'feel' like a better brake without a booster because it will tend to vibrate a bit more, giving more sound and more bite. But a booster stops the stays flexing putting more of the effort onto the rim, increasing hold. I know you know this, but just for anyone else out there. However, brakes are black magic and everyones are different so i'm not gonna argue with you. EDIT: Also I don't need a picture to confirm that you arn't lying to me about your brake set up, life is too short, don't worry about it lol. 1 Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted April 25, 2013 Report Share Posted April 25, 2013 I'm sure you are. I'm just sayin' a booster will increase hold but DECREASE bite. So agreed, will 'feel' like a better brake without a booster because it will tend to vibrate a bit more, giving more sound and more bite. But a booster stops the stays flexing putting more of the effort onto the rim, increasing hold. I know you know this, but just for anyone else out there. However, brakes are black magic and everyones are different so i'm not gonna argue with you. EDIT: Also I don't need a picture to confirm that you arn't lying to me about your brake set up, life is too short, don't worry about it lol. Yeah sorry for coming across like a knob. The booster should in theory give it better hold, but in my instance it didn't, for some reason the brake slipped and the noise was minimal (obviously due to the lack of vibrating cause by the booster.) Back on topic, Try taking the booster off (there's no harm in trying) also try regrinding, and make sure the pads hit the rim square. Quote Link to comment Share on other sites More sharing options...
bike_dummie Posted April 25, 2013 Author Report Share Posted April 25, 2013 Thanks alot guys i will try the brake without a booster and i will ask ali to re-grind my rim when he gets a chance as admittedly mine wasn't the best Is investing in a 4 finger lever worth it? how spongey does it make the brake feel? Thanks Adam Quote Link to comment Share on other sites More sharing options...
trialsiain Posted April 25, 2013 Report Share Posted April 25, 2013 Thanks alot guys i will try the brake without a booster and i will ask ali to re-grind my rim when he gets a chance as admittedly mine wasn't the best Is investing in a 4 finger lever worth it? how spongey does it make the brake feel? Thanks Adam I was using an echo 24 frame with tnn clamps and a tt booster straight on top with shorter bolts.. bite and hold was amazing and lever was solid with a 4 fingerer Quote Link to comment Share on other sites More sharing options...
customrider-Rhys Posted April 25, 2013 Report Share Posted April 25, 2013 personally i would regrind, re setup, make sure you have a good bleed and get a 4 finger lever, with a good bleed you will hardly notice the sponginess, i wouldn't take the booster off till you've tried that yet. boosters do increase your hold, and with a 4 finger lever it should work amazingly, if it doesn't after all that then take the booster off, do a process off elimination out of interest what year brake and pads are you using? Quote Link to comment Share on other sites More sharing options...
Blake Posted April 25, 2013 Report Share Posted April 25, 2013 Thanks alot guys i will try the brake without a booster and i will ask ali to re-grind my rim when he gets a chance as admittedly mine wasn't the best Is investing in a 4 finger lever worth it? how spongey does it make the brake feel? Thanks Adam Just grind it yourself if you're gunna do it again, practice makes perfect no one does a perfect grind first time, but by the third rim i'd done they were pretty much perfect Quote Link to comment Share on other sites More sharing options...
bike_dummie Posted April 25, 2013 Author Report Share Posted April 25, 2013 I was using an echo 24 frame with tnn clamps and a tt booster straight on top with shorter bolts.. bite and hold was amazing and lever was solid with a 4 fingerer Thanks I will defiantly try this before I get rid of the booster was it carbon or alloy as I have both to try personally i would regrind, re setup, make sure you have a good bleed and get a 4 finger lever, with a good bleed you will hardly notice the sponginess, i wouldn't take the booster off till you've tried that yet. boosters do increase your hold, and with a 4 finger lever it should work amazingly, if it doesn't after all that then take the booster off, do a process off elimination out of interest what year brake and pads are you using? 05 slaves on a sl body with 05 internals personally i would regrind, re setup, make sure you have a good bleed and get a 4 finger lever, with a good bleed you will hardly notice the sponginess, i wouldn't take the booster off till you've tried that yet. boosters do increase your hold, and with a 4 finger lever it should work amazingly, if it doesn't after all that then take the booster off, do a process off elimination out of interest what year brake and pads are you using? 05 slaves on a sl body with 05 internals Just grind it yourself if you're gunna do it again, practice makes perfect no one does a perfect grind first time, but by the third rim i'd done they were pretty much perfect Ok I will try again, and any tips? Quote Link to comment Share on other sites More sharing options...
Blake Posted April 25, 2013 Report Share Posted April 25, 2013 Ok I will try again, and any tips? check the tnn video just go at it steady and think about what you're trying to do before you start, just cutting grooves in the rim. also try and be consistant and get the right angle Quote Link to comment Share on other sites More sharing options...
trialsiain Posted April 25, 2013 Report Share Posted April 25, 2013 Hey it was the alloy one but im sure carbon might work too ? Quote Link to comment Share on other sites More sharing options...
bike_dummie Posted April 25, 2013 Author Report Share Posted April 25, 2013 check the tnn video just go at it steady and think about what you're trying to do before you start, just cutting grooves in the rim. also try and be consistant and get the right angle Thanks for the tips i will look at the video aswell Hey it was the alloy one but im sure carbon might work too ? I may aswell use the alloy one as you say it works well Thanks Adam Quote Link to comment Share on other sites More sharing options...
