trialsbikingnunn Posted April 21, 2013 Report Share Posted April 21, 2013 i wanted to raw my anodised purple pedals because they just look gash. Would soaking them in caustic soda ruin the bearings? Quote Link to comment Share on other sites More sharing options...
Danny00135 Posted April 21, 2013 Report Share Posted April 21, 2013 Take out the axle and bearings... Problem solved Quote Link to comment Share on other sites More sharing options...
trialsbikingnunn Posted April 21, 2013 Author Report Share Posted April 21, 2013 im not sure how too? i have onza shindig pedals Quote Link to comment Share on other sites More sharing options...
harmertrials Posted April 21, 2013 Report Share Posted April 21, 2013 It won't touch the bearings Quote Link to comment Share on other sites More sharing options...
Danny00135 Posted April 21, 2013 Report Share Posted April 21, 2013 15mm spanner on the axle, alen key on the end cap undo it.. Then you should be able to get a socket in there to undo the axle.. But Jack's cleared it up so no need to worry.. Quote Link to comment Share on other sites More sharing options...
trialsbikingnunn Posted April 21, 2013 Author Report Share Posted April 21, 2013 ahh okay, thanks for the help 1 Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted April 21, 2013 Report Share Posted April 21, 2013 Use an old toothbrush and just scrub away, this method saves your bearing grease from being flushed away. Quote Link to comment Share on other sites More sharing options...
Jake. Posted April 22, 2013 Report Share Posted April 22, 2013 (edited) Rawed my orange echo tr platforms like around June last year with Jack reassuring me it'll be fine, still on same set of pedals. ^ With no issues. Edited April 22, 2013 by JMCD Quote Link to comment Share on other sites More sharing options...
ooo Posted April 22, 2013 Report Share Posted April 22, 2013 You don't need to soak things to be rawed, just fill a cup with warm water and caustic soda and then wear a rubber glove and rub it on using a cloth, it takes about 10 seconds to come off. Also its best to do near a cold tap to rinse off the excess. Quote Link to comment Share on other sites More sharing options...
AkuskaUK Posted April 22, 2013 Report Share Posted April 22, 2013 Would rawing weaken certain items? Such as the forks, frame and rims? Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted April 22, 2013 Report Share Posted April 22, 2013 Good question! I guess it won't, as Joe Maher and Tom Rankin both rawed their Rockmans. 1 Quote Link to comment Share on other sites More sharing options...
AkuskaUK Posted April 22, 2013 Report Share Posted April 22, 2013 I suppose not! I was thinking about rawing all I said, scared that it might weaken it to break since I'm not in any way a smooth rider! Quote Link to comment Share on other sites More sharing options...
harmertrials Posted April 22, 2013 Report Share Posted April 22, 2013 Doesn't weaken it at all, unless you left it in there for a significant amount of time. I'm a raw whore. Quote Link to comment Share on other sites More sharing options...
Jake. Posted April 22, 2013 Report Share Posted April 22, 2013 (edited) Well I'm not a smooth rider and seriously it doesn't weaken it, just raw your shizzle. Edited April 22, 2013 by JMCD Quote Link to comment Share on other sites More sharing options...
AkuskaUK Posted April 22, 2013 Report Share Posted April 22, 2013 How long should I leave it on there for? Sorry for hijacking your thread man, easier than making a new one. Quote Link to comment Share on other sites More sharing options...
harmertrials Posted April 22, 2013 Report Share Posted April 22, 2013 A matter of minutes, hot water. Quote Link to comment Share on other sites More sharing options...
Jake. Posted April 22, 2013 Report Share Posted April 22, 2013 What are you rawing? When I did my pedals it took about 30 seconds under the caustic then I put it in a bowl of water. When I wiped my try all rim with caustic it took about 5 wipes. Depends on strength of the mix too. Quote Link to comment Share on other sites More sharing options...
AkuskaUK Posted April 22, 2013 Report Share Posted April 22, 2013 In rawing: Because Color frame, echo urban 2013 forks and front and rear echo tr rims Quote Link to comment Share on other sites More sharing options...
Blake Posted April 22, 2013 Report Share Posted April 22, 2013 In rawing: Because Color frame, echo urban 2013 forks and front and rear echo tr rims Are those forks anodised or painted? Caustic soda won't ruin the aluminium as long as you get rid of it once the anodising has gone, as it can eat aluminium but it takes a lot longer than it does to get rid of the anodising. Rawing frame and rims and stuff should be fine, the only thing i'd be wary of rawing is rim brake bodies, as if you increase the inner diameter of the bore then it can make a leaky leaky Quote Link to comment Share on other sites More sharing options...
AkuskaUK Posted April 22, 2013 Report Share Posted April 22, 2013 Forks and rims are anodised if I recall, thanks though Quote Link to comment Share on other sites More sharing options...
AkuskaUK Posted April 22, 2013 Report Share Posted April 22, 2013 After rawing, what should i do then? polish and lacquer? Quote Link to comment Share on other sites More sharing options...
Jake. Posted April 22, 2013 Report Share Posted April 22, 2013 After rawing, what should i do then? polish and lacquer? I used wire wool and then polished. Never bothered with lacquer. After rawing, what should i do then? polish and lacquer? I used wire wool and then polished. Never bothered with lacquer. Quote Link to comment Share on other sites More sharing options...
AkuskaUK Posted April 22, 2013 Report Share Posted April 22, 2013 I live on the Isle of Wight and always ride near the sea, wont the aluminium oxidise? or rust? Quote Link to comment Share on other sites More sharing options...
trialsbikingnunn Posted April 22, 2013 Author Report Share Posted April 22, 2013 aluminium doesnt rust... Quote Link to comment Share on other sites More sharing options...
AkuskaUK Posted April 22, 2013 Report Share Posted April 22, 2013 Proves how much i know about metals Oxidise the right word? Ill get on with it tomorrow then! What should i use to polish it? Quote Link to comment Share on other sites More sharing options...
