Rotor help
harmertrials
Hi all. I just won these on ebay for my mod - http://www.ebay.co.uk/itm/HOPE-Mono-Mini-Pro-Disk-Brake-Set-Carbon-Levers-Ti-Bolts-Gunsmoke-Grey-/281093265230?_trksid=p2047675.l2557&ssPageName=STRK%3AMEWNX%3AIT&nma=true&si=0%252Fh4NT%252BVtwe8dJ5JBYzB2KJdUqI%253D&orig_cvip=true&rt=nc
I'm wondering if I can get away with running the floating rotors or not?
Also any pad recommendations or am I good to use the standards?
Cheers
Id stay clear of the discs. Its been said before the Hope floating rotors aren't all too good for trials use. You could probably sell them on and have enough for a pair of decent standard rotors.
Shimano Ice Tech rotors seem to be the exception to the rule...
As for pads, standards should be more than up to the job. Mates jump rigs got a set of said brakes on and they're brutal.
  • Like 1
