Hope Pro 2 front hub, bolt on conversion.
AkuskaUK
Thanks :) Just found the adapters, how would it bolt onto the hub and keep it strong? My rear Pro2 has a meaty axel that runs though it, this seems to only have the end caps... would it just bolt onto that? how is there any strength there?
you change the end caps, then theres a massive 9mm bolt that runs through the entire hub and dropouts and holds everything together.
Its like QR, just ALOT stronger.
I wouldn't recommend QR's for spins or gaps to 90 but for anything else I wouldn't see it been a problem.
My TT QR has far outlasted the Hope QR I had if anyone looks in here for QR advice.....
but yer I can wait to have bolts again!
