Cap's RockMan Liberte
Mark W
After a joyous year together, Cap has retired his Gelpr and replaced it with a shiny new red frame.
General spec is the Liberte frame built with a bunch of Trialtech Sport and SL parts, with a Der Baron rear tyre and Try-All Stiky front tyre.
EDIT: Weight update: 9.36 (you sucks dicks) kg.
  • 1 year later...
Bit of an uber bump but wondered if Cap had any problems with the driveside crank hitting the chainstay? Under power mine just clips it, running a Trialtech Sport Lite BB with Echo spacer on the driveside and Tryall CNC cranks.
The gaps not even 1cm
but still, there is a gap there
Now on power something bends and that gap disappears... Am I on the right track or I should get back to work learning about phones and switching power supplies?
