Working out the maximum bending moment from a simply supported beam?
dann2707
Hey. The final touch for extra marks on my report for tomorrow is to work out the actual maximum bending moment from a bridge beam.
Can anyone tell me what is it or how to work it out? The two upwards facing arrows are where the supports are.
Cheers!
Maximum bending moment to achieve what criteria? If the maximum stress exceeds the yield stress it will plastically deform, if it exceeds the ultimate tensile strength it will fail.
To calculate it you would need to know what material it is (in other words know the yield and ultimate strengths) and what the section size and loadings are. If you don't know this information then it can only be a hypothetical answer :)
  • Like 1
You need to know the properties of the material you are trying to bend, or as the lad says, it can only be an Estimate/hypothetical answer. The base information has to be accurate, or the force you would need to use would be too much, or not enough.
Edited by bing
The beam is made from square hollow section steel. I know some other figures that we were given / ive worked out
M: The max bending moment = 400Kn/m (this figure is given to us but we are supposed to work out the actual max bending moment)
Ixx: The total second moment of area = 29.71 x10^-3 m^4
y: Distance between neutral axis and bottom of the lower beam = 0.875m
E: Youngs modulus = 207 Gn/m^2
σ = y F L / 4 I
So 8.84 MPa I think...
EDIT: oops I worked out max bending stress rather than moment
2nd Edit: I think max bending moment is actually quite simple for this simple beam. M=FL/4 -> 300KNm I think....
Edited by Pete.M
  • Like 1
For a simply supported beam in that instance the maximum bending moment would be at the center.
Pete was close with PL/4 however that is not your max. That will give you the moment for just the point load. You need to also take in to account the UDL.
Max = PL/4 + WL2/8
