stupid rounded bolt....help please
trials hoe
right so i've just gone dual maggie, and went to undo the bolt to bleed it and it went all gay and rounded its self.......
bolt is exactly as per the old pic below -
any ideas how i can get this out? i doubt cutting a slot into the head will do the job and the bolt head is on an angle so i cant whip the lever off and grip it in the vice :(
any help would be much appreciated guys
chris :)
The slot method works well although it looks like it may be awkward to achieve in that location
i can take the lever off no problem, i'm not sure there is enough material to lever against to undo it. i don't want to end up taking the whole head off it, then i'll be f**ked :(
