trialsiain Posted March 31, 2013 Report Share Posted March 31, 2013 I've been watching videos and see people side hopping onto rails and walls with huge drops on other side. But when I sidehop I usually like fly over the other side of the wall or pallet after landing. How can I get more control ? Quote Link to comment Share on other sites More sharing options...
Jake. Posted March 31, 2013 Report Share Posted March 31, 2013 (edited) The way I see it, if you do sidehops on stuff that you feel is small for your ability you're able to get on top of it really easy... Like I can sidehop onto a low rail around 20 inch at my skatepark super easy but I struggle on a sidehop that's higher than bar height. But people who are used to like 50" sidehops or more will be able to go onto 40" easy, therefore they can focus more on where the wheels go rather than height. Edited March 31, 2013 by JMCD Quote Link to comment Share on other sites More sharing options...
WIGAN ?? Posted March 31, 2013 Report Share Posted March 31, 2013 its hard to explain but if you pre load down and spring up as fast as you can just concentrate on going straight up dont worry about any side ways movements just yet, when you're at the peak of your hop bring your knees up and to the left (to the right if youre left footed obviously) this should help you to stay on the wall better as there is very little sideways momentum since youve just jumped up, sounds like what you're doing is literally a sideways hop so its just throwing you over the wall once you're on it, hope this helps Quote Link to comment Share on other sites More sharing options...
Danny00135 Posted March 31, 2013 Report Share Posted March 31, 2013 All to do with the direction of momentum, If you're just landing on it you'll find your momentum will be sideways, wanting to throw you over, Whereas if you can land "on" it your momentum will be less sideways. More tuck and power into the preload and you'll land "on" it.. Quote Link to comment Share on other sites More sharing options...
Lewis Gething Posted March 31, 2013 Report Share Posted March 31, 2013 Yeah, it sounds to me like you need to just aim to land on the edge of the wall almost, rather than trying to jump sideways, go upwards as much as possible, then you wont have to worry about momentum carrying you sideways Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted March 31, 2013 Report Share Posted March 31, 2013 its hard to explain but if you pre load down and spring up as fast as you can just concentrate on going straight up dont worry about any side ways movements just yet, when you're at the peak of your hop bring your knees up and to the left (to the right if youre left footed obviously) this should help you to stay on the wall better as there is very little sideways momentum since youve just jumped up, sounds like what you're doing is literally a sideways hop so its just throwing you over the wall once you're on it, hope this helps If it only was so easy Quote Link to comment Share on other sites More sharing options...
bing Posted March 31, 2013 Report Share Posted March 31, 2013 I can't side hop to save my life. The most I've ever done is 3 pallets, and I bet I've tried less than ten times. It's summat I've never learned Quote Link to comment Share on other sites More sharing options...
trialsiain Posted March 31, 2013 Author Report Share Posted March 31, 2013 yea i think i know what you mean by needing to go up instead of too much to the side.. the highest ive done is 7 pallets but usually when i try and land it it throws me over the other side of the pallet Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted March 31, 2013 Report Share Posted March 31, 2013 (edited) yea i think i know what you mean by needing to go up instead of too much to the side.. the highest ive done is 7 pallets but usually when i try and land it it throws me over the other side of the pallet That´s exactly what happens when you go sideways instead of bike, trust me, it happens to me all the time lol. The sad part is I know what to do to stop it, but cannot really do it that way. Old habbits die hard... Edited March 31, 2013 by ghostrider88 1 Quote Link to comment Share on other sites More sharing options...
trialsiain Posted March 31, 2013 Author Report Share Posted March 31, 2013 I noticed its worse when i try to land front wheel first cause the wheel lands then the back one keeps going Quote Link to comment Share on other sites More sharing options...
matthew_coggan Posted April 1, 2013 Report Share Posted April 1, 2013 yea i think i know what you mean by needing to go up instead of too much to the side.. the highest ive done is 7 pallets but usually when i try and land it it throws me over the other side of the pallet I have this problem 2 with 6 pallets its fine but 7 I worrie about the front not makeing it so over compensate with sideways momentum so my foot ends up going down Quote Link to comment Share on other sites More sharing options...
CalopS Posted April 1, 2013 Report Share Posted April 1, 2013 You could put a thin piece of timber on the edge of a pallet and practice with that by adding more pallets under it? Quote Link to comment Share on other sites More sharing options...
SamKidney Posted April 2, 2013 Report Share Posted April 2, 2013 As per WIGAN, focus on going up more. The tuck/bar rotation should push the bike across to the left/right enough to land the bike on the object without too much sideways momentum. Quote Link to comment Share on other sites More sharing options...
trialsiain Posted April 3, 2013 Author Report Share Posted April 3, 2013 As per WIGAN, focus on going up more. The tuck/bar rotation should push the bike across to the left/right enough to land the bike on the object without too much sideways momentum. its hard to explain but if you pre load down and spring up as fast as you can just concentrate on going straight up dont worry about any side ways movements just yet, when you're at the peak of your hop bring your knees up and to the left (to the right if youre left footed obviously) this should help you to stay on the wall better as there is very little sideways momentum since youve just jumped up, sounds like what you're doing is literally a sideways hop so its just throwing you over the wall once you're on it, hope this helps Do you move body towards wall or away mid air ? cause i see damon watson landing on oppisite side of bike Quote Link to comment Share on other sites More sharing options...
WIGAN ?? Posted April 4, 2013 Report Share Posted April 4, 2013 Do you move body towards wall or away mid air ? cause i see damon watson landing on oppisite side of bike your body doesn't move at all in terms of sideways movement its all in your knees, yeah you will end up hanging off one side of the bike and when your wheels are on top of the wall then you can pull your body up with your arms/legs and regain your balance, its easier said than done but thats the basic jist and its something to practice at Quote Link to comment Share on other sites More sharing options...
