picowatt Posted March 27, 2013 Report Share Posted March 27, 2013 I would like some information regarding these plazmatic red CRV brake pads. Anyone have first hand experience with them. All information is appreciated. I don't think they are made anymore but I found some. Can new material be fitted into these backings If these are bad I will try rockman Blues Quote Link to comment Share on other sites More sharing options...
ogre Posted March 27, 2013 Report Share Posted March 27, 2013 Just try them... I found the tnn lgv pads to be siiiiiick if you have no luck with the reds Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted March 27, 2013 Report Share Posted March 27, 2013 I will try rockman Blues There you go. 1 Quote Link to comment Share on other sites More sharing options...
LiamWood! Posted March 27, 2013 Report Share Posted March 27, 2013 It's the CRVs in yellow that you want. Quote Link to comment Share on other sites More sharing options...
craigjames Posted March 27, 2013 Report Share Posted March 27, 2013 Didn't think that Plazmatic CRVs were made in red, of the 4 pairs i had they were all yellow. Great bite, good hold, but not great wear on anything but a smooth grind. The original Plazmatic backings were longer than normal pads and therefore refills from other brands wouldn't fit with out bodging. Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted March 27, 2013 Report Share Posted March 27, 2013 Didn't think that Plazmatic CRVs were made in red, of the 4 pairs i had they were all yellow. Great bite, good hold, but not great wear on anything but a smooth grind. The original Plazmatic backings were longer than normal pads and therefore refills from other brands wouldn't fit with out bodging. There were red as a limited edition I believe http://shop.trialricany.com/?14,brzdove-spalky-plazmatic-crv , but they had the same short wear life on grind Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted March 27, 2013 Report Share Posted March 27, 2013 CRV backings are longer than magura ones so you would need to cut some material to fit them Quote Link to comment Share on other sites More sharing options...
picowatt Posted March 27, 2013 Author Report Share Posted March 27, 2013 Ok. Don't want to cut material. It's expensive enough as is Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted March 27, 2013 Report Share Posted March 27, 2013 Ok. Don't want to cut material. It's expensive enough as is What he meant is you would have to find some larger block of polyuretane to make your own refills because other pads are shorter Which isn´t ideal if you don´t like a lot of trial/error. Quote Link to comment Share on other sites More sharing options...
Bunta Posted March 27, 2013 Report Share Posted March 27, 2013 expressive bikes has the LGv pad refills to fit the old backings Quote Link to comment Share on other sites More sharing options...
picowatt Posted March 29, 2013 Author Report Share Posted March 29, 2013 Ok. I found a shop in the US that has some Coust/sink v pads. Any info about them? Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted March 29, 2013 Report Share Posted March 29, 2013 Not as good as rockpads, but still good nonetheless. 1 Quote Link to comment Share on other sites More sharing options...
picowatt Posted April 17, 2013 Author Report Share Posted April 17, 2013 Rock man blues ordered. Can't wait to try them. Do they require a sharp grind or does any grind work? Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted April 17, 2013 Report Share Posted April 17, 2013 They work great on any type of gring, but sharp medium grind is the best of course. Quote Link to comment Share on other sites More sharing options...
Blake Posted April 17, 2013 Report Share Posted April 17, 2013 gring Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted April 18, 2013 Report Share Posted April 18, 2013 What I meant is gringo. Quote Link to comment Share on other sites More sharing options...
picowatt Posted April 27, 2013 Author Report Share Posted April 27, 2013 Pads finally came in. Installed and used new brake cable all lubed up. Headed to the new Indoor park tonight to try them out Quote Link to comment Share on other sites More sharing options...
