Stan's Ti leaking help.
Si whitby
Hi guys I've got a problem with leaking on my Ti maggie fittings. Firstly does anyone suffer from a similar problem. I have to Rebleed my brakes before I go on every ride. It seems as if the bore is too small to compress the olive onto the hose. I've tried using the old fitting to crimp the olives at one end then slid the new one on. But you can only do this on one end meaning that the end fitted just the Ti part is the leaking point. Cheers for any help. (Bet Craig has in idea)
A mate had a similar problem on a ride last night... We were going to try tighten the bolt into the slave a bit more, unless anyone comes up with a different idea?
Joe that sounds like what happened, might just need a new olive.
Edited by JMCD
