4-finger or 2-finger levers?
chris_trials
I currently run the 2011 HS33's front and rear with the 4-finger levers. What I've been pondering is whether I should stick with the 4-finger levers and wait till the come back in stock at tartybikes or should I go for the 2-finger levers. Is there a noticeable difference in power between the two lengths or are they fairly similar?
  On 3/25/2013 at 4:16 PM, Danny00135 said:
Dependent on frame this is.
If the frame is quite flexy then more power can be a bad thing.
But 4 finger will give you more power
then get a booster if its too flexy, more leverage is always more power.
  • Like 2
most maggies have big bleed holes so they need 4 fingers.
(A)
nah,to stay serious,i think its personal preference like soft or hard shoe soles...
i had the 4 finger blades on for years now,always made the frame flex a lil bit more,but 2finger blades had just a too hard feeling.
Edited by FamilyBiker
  • 11 years later...
