Neon Bow 2012
Danny00135
I've been meaning to do this for a good while now, and given the weathers beautiful but un-ridable what better time than now :)(Y)
314967_10200567050595941_1068162966_n.jp
Spec:
Frame: Neon Bow 2012
Forks: Echo SL (Still got my teeth boys :D)
Headset:Echo SL
Stem: Try all 3D (Again, Still got all teeth)
Handle Bars: Rockman 7050 Riser (with TT thin foams)
Cranks: Trialtech
Freewheel: Echo SL
Pedals: Echo TR platform
Wheels: Front: Tyre-Try-all
Rim - Neon Light
Hub - Zhi Disc Hub
Spokes - Unsure (black ones XD)
Rear: Tyre - Try-all
Rim - Zhi (incredible rim!!)
Hub - "Echo TR"
Spokes - Unsure (Black with the odd silver ;))
Brakes: Front - Avid BB7
Rear - 05 Maggie with Coust Pads
I'm chuffed to bits with this now, I've gradually built it up from an 05 Pitbull, The only thing that's stayed from that is the rear brake XD
Cheers for looking :)
  • Like 2
Tidy build.
Needs more rotor up front :P
Agreed.
The reason it's only a 160 is I never had a front brake, well I had a maggie but I was having that many problems with it that I took it off,
ran it without a front brake and I much prefered it, only got the front disc so I'd stop destroying my Tyre skidding to stop XD and the 160 was available at the time (Y)
Got used to front wheel moves now so I think I'll change to a bigger one :)
  • Like 1
always had a soft spot for the bow frames :) black forks, cranks, stem and rear rim and it'd be swish (Y)
how are you finding the rockman bars? the silver ones i had felt a bit on the floppy side :ermm:
zhi rim looks an awful lot like the rockman rim i have too. haha the only part that has made it from all the previous builds i've ran is my fw......
  • Like 1
Bars feel ok,
The forks are super flexy so I can't really tell XD
