isitafox Posted March 21, 2013 Report Share Posted March 21, 2013 Anyone got any good ideas of how to remove a stuck piston from an 05 magura body? I would use an airline and blow it out but I'm at work and haven't got one handy, would it help if I bathed it in a sink of hot water to try and make the lever body expand enough for the piston to pop out? Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted March 21, 2013 Report Share Posted March 21, 2013 Track pump and bleed hose. Quote Link to comment Share on other sites More sharing options...
Mark W Posted March 21, 2013 Report Share Posted March 21, 2013 It's worth keeping an eye on as it's coming out, so open your eye really wide when you're doing it and try and look straight down the cylinder 1 Quote Link to comment Share on other sites More sharing options...
isitafox Posted March 21, 2013 Author Report Share Posted March 21, 2013 Track pump and bleed hose. Just my luck my pump is under the wifes pushchair! It's worth keeping an eye on as it's coming out, so open your eye really wide when you're doing it and try and look straight down the cylinder Tried this before when I was trying to work out why the hosepipe was blocked Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted March 21, 2013 Report Share Posted March 21, 2013 (edited) lever or slave? if its the lever unscrew the bleed bolt and push it out with a spoke or something similar Edited March 21, 2013 by FamilyBiker Quote Link to comment Share on other sites More sharing options...
isitafox Posted March 21, 2013 Author Report Share Posted March 21, 2013 Sorted now, a bath in really hot water followed with good old fashioned violence (banging it on the desk) 1 Quote Link to comment Share on other sites More sharing options...
Maxx Posted March 21, 2013 Report Share Posted March 21, 2013 Track pump and bleed hose. Quote Link to comment Share on other sites More sharing options...
WIGAN ?? Posted March 21, 2013 Report Share Posted March 21, 2013 bleed it as normal block the lever grub screw off refill the syringe and push like f**k, should pop out 1 Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted March 21, 2013 Report Share Posted March 21, 2013 he sorted it already ,16 mins ago Quote Link to comment Share on other sites More sharing options...
WIGAN ?? Posted March 21, 2013 Report Share Posted March 21, 2013 alright chill out you bellend 3 Quote Link to comment Share on other sites More sharing options...
Danny00135 Posted March 21, 2013 Report Share Posted March 21, 2013 Sorted now, a bath in really hot water followed with good old fashioned violence (banging it on the desk) How would you like it if I banged you on the desk?!?!?! 1 Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted March 21, 2013 Report Share Posted March 21, 2013 (edited) alright chill out you bellend How would you like it if I banged you on the desk?!?!?! :wink2: especially because your tip was to get showered with oil if it isnt a new syringe Edited March 21, 2013 by FamilyBiker Quote Link to comment Share on other sites More sharing options...
isitafox Posted March 21, 2013 Author Report Share Posted March 21, 2013 I enjoy a good banging! Would appear the piston is swollen to f**k, not sure what it's supposed to be like but there's barely any difference at all between the piston and the o ring. Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted March 21, 2013 Report Share Posted March 21, 2013 (edited) I enjoy a good banging! Would appear the piston is swollen to f**k, i know that,once somethings swollen,i have to bang. sorry couldnt resist as for the b...end:isnt insulting someone not allowed in here,isitafox? Edited March 21, 2013 by FamilyBiker Quote Link to comment Share on other sites More sharing options...
isitafox Posted March 21, 2013 Author Report Share Posted March 21, 2013 Well, apparently I'm quite mistaken and the fact the piston was so obscenely tight in the lever is nothing to do with the fact it has swollen and was in fact my fault for trying to lube it depending on what type of lube you have used to oil the front piston it could be stick up there via suckstion Quote Link to comment Share on other sites More sharing options...
customrider-Rhys Posted March 21, 2013 Report Share Posted March 21, 2013 thats crap you need to lube it! mineral oil, finish oil, or Vaseline would do it Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted March 21, 2013 Report Share Posted March 21, 2013 Don't get stung by online trials shop prices for o ring prices I'll give you some for free Quote Link to comment Share on other sites More sharing options...
