HS33 05, lever piston stuck!
Canardweb
Ok, as I have already told in another thread, I have problems with my 05 HS33. I want to get the piston out of the lever, but after searching the forum, it sounds like a swollen piston because of the water bleed. My problem is, I can't get the piston out. I tried pushing as much as I could on a syringe fixed to the brake but it still doesn't want to come out. I tried getting it with a tool, but the tool keeps slipping.
Has anybody ever had that problem and found a way to fix it?
Please help me!
The spoke method works well for '04 Magura's, not for the '05s.
Edit: I remember somebody a while ago somehow fitting a track pump to the bleed hole, then simply pumping the piston out.
Edited by cai
usually I put the hose in the presta side of the pump. and use the m8 port with a main line 'cos of the greater air volume.
Also, slight safety tip. Fold the TPA rod into the lever blade and put the lever and bolt back in before you this method.
This will then make it a two stage process, the piston will pop against the lever,(IME this is the 'dangerous' bit cos it takes the most pressure to do, 110 psi in one case), then you take the blade out and repeat. Aim the master into a corner with some foam padding or similar because that sh1t goes miles!! ha ha.
Find the bits, lightly sand the piston (especially the bottom half, that's the bit that sticks) avoiding the O-ring like it's got plague, fit piston with a good smear of Vaseline and check for buttery movement with a screwdriver where the rod should go.
Job should be mint :wink:
Edited by CC12345678910
