Nick Wood Rig One - Echo Pure SL 2013
N.Wood
Some pics of my bike in its current state.
Echo SL 2013 frame w/ titanium Spanish BB
Trialtech disk forks (2 years old)
Echo SL headset
Rockman stem
Try-all carbon bars
Try-all purple sky front rim on try-all H hub w/ sapim race spokes
Try-all Stiky front tyre
Hope mono trials 200mm
Magura rear w/ TNN LGMs, try-all clamps
Try-all cranks with symetrik bash, Echo SL fw, Wellgo MG-1s
KMC Z610HX chain
Trialtech SL rim on Neon splined rear hub w/ trialtech sprocket and sapim race spokes
Continental rain king w/ conti tube
Titanium bolts on: stem, front axle, rotor, pedal axles (to be fitted)
No idea on weight, works good with decent tyres and quiet front brake.
99% is available at http://tartybikes.co.uk
  • Like 2
Nice and clean looking. No plans to run a rear brake booster?
Not really, seems to work ok without one and quite like a bit of flex, makes it easier on the ol' braking finger after long natural lines or whatever.
  • Like 1
  • 2 weeks later...
looks swishhhhhhh, nice to see a disc up-front on a stock :)
sure thats a tt sl rim on the back? thought they had a 0 spoke offset? looks like a rockman single wall to me.....
You are correct mr hawkeye, its a rockman :)
I did have a TT, but after the ~17th rear rim you own you tend to lose track haha.
  • Like 1
Yeah from what I've found it seems to be pretty good, I've not found a modern rim that holds grinds specifically better than others as each ride the conditions are different and so it always changes. But yeah seems to work as good as the others, still straight after a 8 months or so, pretty light, clean looking graphics, nothing bad to say to be honest!
  • Like 1
  • 3 weeks later...
It's a Trialtech Race splined sprocket - The Neon hub is splined and the big spanner-looking thing is the lockring to keep the sprocket tight. I got fed up of threads on hubs. I cracked the original neon sprocket and tarty replaced it with this TT one.
All has been workign well for a year or so now (Y)
