Echo SL Freewheel
cai
I've not properly used a rear free hub but reading all this stuff about how good the hopes are, I think I may sway in that direction when I need to rebuild my rear wheel.
How much of a difference does it actually make by shifting the weight forward by using a ffw?
not much, but when you add those extra 150g and half the EPs, it starts to make a difference.
If you show me someone who can notice 150g in weight, I'll show my arse in woollies window. No way on this earth can anybody notice that small amount
saving weight is subject to where you're saving it, you may not notice it around the bb area but i noticed a saving of just short of 150g when i drilled my front rim into near oblivion. that said i noticed no weight difference when i put my carbons on (saving of 100g ish)
didn't woolies go belly-up a while back? get to m&s thats not just any arse...................
It depends where that weight sits. 150g heavier BB you won´t feel, 150g heavier tire you will. The point is most kids here spend their pocket money on ti bolts to save 50g on whole bike, carbon bars etc. adding 150g would be painful for them I believe lol. Dammit trials hoe, didn´t read your post, funny how BB example came to my mind as well.
Edited by ghostrider88
  • Like 1
Iv had the same echo freewheel since 09 and it's still going fine. Still on my practice bike, I'd rather have a light rear hub and a heavy component on my bb. You will notice a big difference that way
Running a FFW is definitely better for weight distribution, but seeing as no one can recommend me a viable replacement for my broken SL then I'm turning to the reliable option of a Pro2.
Echo sl will be fine
2 echo SL's exploded on today's donny ride, one was 5 days old.
One was andee's, which was 2 months old, and the other was Damon's, which came on Friday. Not a good showing for echo at the moment, and chris's broke in scunny in November
Would be epic if they were made like the first lot. Feeleys got one of the original SL freewheels on his mod and it sounds completely different to my newer black SL.
Unfortunately, Echo do not want to admit something is wrong with the newer batches. Apparently dealers don't complain, which is strange because the failure rate of these is completely unacceptable. 1% per year would be bad enough. Perhaps someone should collect the damaged freewheels and send a 100kg box of remains to Deng, then he'd understand?
Edited by Greetings
  • Like 2
The problem is Ozzy, as I understand it, the freewheel that lasted me over 2 years isn't the same one being sold today. The new batch is worse (as verified by some of the comments in this topic).
I like to use the tensile 60, works fine for me and I have a spare on a spare crank arm ready for if it fails mid comp so i can just put the new one on in minutes, I can't really carry a spare wheel round though if a hope hub snaps the pawls springs or shifts the drive ring in the hub. I know those are very unlikely but it a ride ending fail.
