Need to borrow or get measurements from a magura piston
isitafox
Anything you can get, length, diameter, sizes of the recesses in the ends, distance to where the o ring sits, etc. Basically need to make an accurate drawing up for the machinist to go off to see how much it's gonna cost to get a load made. Would be a massive help if you could!
  • Like 1
Yeah I'll get some advice from the guys there when they look at the design. It's a pretty big company that deals in a lot of different industries worldwide so they should be able to advise on what will work best. Might end up being too expensive or the minimum order quantity might be a ridiculous amount but without asking I won't know.
