Half Bash Set Up.
dngr2self
Glad im not the only one that had issues. The lip to hold it away from the freewheel destroyed itself because it was to thin, so i ended up filing it off and using a washer to space it out
Yeah that's it, it cracked after the silly thin integrated washer wore down.
Think that through again dude!
When you put a half bash on, the crank tightens onto the bash, the crank goes on clockwise, the bash stays in place so therefore it's going anti clockwise. I put the half bash halfway behind the crank and when it tightens it goes into the correct place... Where am I going wrong?
