Jake. Posted February 22, 2013 Report Share Posted February 22, 2013 I've tried gluing them to the bars, aftershave, deodorant and they're still slipping... Really puts me off when riding, any solutions? Quote Link to comment Share on other sites More sharing options...
CalopS Posted February 22, 2013 Report Share Posted February 22, 2013 The normal or thin ones? I just use water on the normal ones. Quote Link to comment Share on other sites More sharing options...
Jake. Posted February 22, 2013 Author Report Share Posted February 22, 2013 (edited) Thin ones. Water?? Edited February 22, 2013 by JMCD Quote Link to comment Share on other sites More sharing options...
isitafox Posted February 22, 2013 Report Share Posted February 22, 2013 wd40 Quote Link to comment Share on other sites More sharing options...
Sam T Posted February 22, 2013 Report Share Posted February 22, 2013 Always used brake cleaner for mine. Make sure your handle bars are clean and free of any oil/grease too Quote Link to comment Share on other sites More sharing options...
CalopS Posted February 22, 2013 Report Share Posted February 22, 2013 Thin ones. Water?? Maybe I should have explained more. I put my grips on with water then let them dry and there solid. I haven't used the thin ones....... Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted February 22, 2013 Report Share Posted February 22, 2013 (edited) hair spray, old bmx trick edit:yeah but clean it first with alcohol no beer,you made it worst with the after shave already haha,contains oils in most cases Edited February 22, 2013 by FamilyBiker Quote Link to comment Share on other sites More sharing options...
Danny00135 Posted February 22, 2013 Report Share Posted February 22, 2013 Semen Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted February 22, 2013 Report Share Posted February 22, 2013 Semen try that after sticking it to a turning brake disc lol (subtile point on another topic haha) 1 Quote Link to comment Share on other sites More sharing options...
trials hoe Posted February 22, 2013 Report Share Posted February 22, 2013 tar, but mine where enough of a twat to get on in the first place so i used evaporating glass cleaner to slip 'em on with. Quote Link to comment Share on other sites More sharing options...
Danny00135 Posted February 22, 2013 Report Share Posted February 22, 2013 tar oh my god I'M NOT THE ONLY ONE Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted February 22, 2013 Report Share Posted February 22, 2013 Spray paint them on. Quote Link to comment Share on other sites More sharing options...
dann2707 Posted February 22, 2013 Report Share Posted February 22, 2013 Water?? Here you go. 1 Quote Link to comment Share on other sites More sharing options...
williams Posted February 22, 2013 Report Share Posted February 22, 2013 I have the exact same problem with the thin TT foams.. Tried everything, but a good amount of locktite does the job. Let it completely dry though.. Quote Link to comment Share on other sites More sharing options...
Danny00135 Posted February 22, 2013 Report Share Posted February 22, 2013 Mine do slip too, But some tar and a good amount of pressure holds them on nicely Quote Link to comment Share on other sites More sharing options...
cai Posted February 22, 2013 Report Share Posted February 22, 2013 I always found that putting any lubricant/water/hairspray/paint in between foam grips and the bar to help them slide on results in them slipping. Try sanding/scratching the bars slightly where the grips will sit, this roughens the surface to make it a little grippier for the foam grips. If you can't get them on then dry then use the cable tie method to slide the grips on easily. 1 Quote Link to comment Share on other sites More sharing options...
Jake. Posted February 22, 2013 Author Report Share Posted February 22, 2013 I always found that putting any lubricant/water/hairspray/paint in between foam grips and the bar to help them slide on results in them slipping. Try sanding/scratching the bars slightly where the grips will sit, this roughens the surface to make it a little grippier for the foam grips. If you can't get them on then dry then use the cable tie method to slide the grips on easily. I use tryall carbons, the surface is roughened already... I think I might do the alcohol to clean it, then try putting it on with a little bit of wd40 or whatever and see if that works. Quote Link to comment Share on other sites More sharing options...
narrowbars Posted February 22, 2013 Report Share Posted February 22, 2013 Clear spray paint lacquer, spray it inside the grips and slide them on. Allow to dry for a couple of hours, then go riding 1 Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted February 22, 2013 Report Share Posted February 22, 2013 I use tryall carbons, the surface is roughened already... I think I might do the alcohol to clean it, then try putting it on with a little bit of GT85 or whatever and see if that works. Used GT85 because it contains PTFE which is silicone which will help it to stick. Quote Link to comment Share on other sites More sharing options...
Jake. Posted February 22, 2013 Author Report Share Posted February 22, 2013 Clear spray paint lacquer, spray it inside the grips and slide them on. Allow to dry for a couple of hours, then go riding Actually that's a good point, going to do that if I have some. Cheers! Quote Link to comment Share on other sites More sharing options...
Danny00135 Posted February 22, 2013 Report Share Posted February 22, 2013 Araldite Quote Link to comment Share on other sites More sharing options...
thinkdougie Posted February 22, 2013 Report Share Posted February 22, 2013 I glue mine Quote Link to comment Share on other sites More sharing options...
Jake. Posted February 22, 2013 Author Report Share Posted February 22, 2013 Didn't have wd40, gt85, lacquer etc, so I used hairspray... Seemed to work ok, hopefully it won't slip Quote Link to comment Share on other sites More sharing options...
Danny00135 Posted February 22, 2013 Report Share Posted February 22, 2013 Didn't have wd40, gt85, lacquer etc, so I used hairspray You're so manly 1 Quote Link to comment Share on other sites More sharing options...
Cap Posted February 22, 2013 Report Share Posted February 22, 2013 I used to use paint on mine, jobs a good un! Quote Link to comment Share on other sites More sharing options...
