rosslittledubber Posted February 21, 2013 Report Share Posted February 21, 2013 Hey guys, Currently running an onza blade with a maxxis tyre on the rear.. Its been running fine for months but today the tyre popped off the rim, now everytime i re-seat it and blow it up i put pressure on the pedals and tyre just pops back off again :/ Help Please and Thanks Quote Link to comment Share on other sites More sharing options...
isitafox Posted February 21, 2013 Report Share Posted February 21, 2013 Is there a tear in the bead? Quote Link to comment Share on other sites More sharing options...
N.Wood Posted February 21, 2013 Report Share Posted February 21, 2013 Or flat spot in rim? Quote Link to comment Share on other sites More sharing options...
dezmtber Posted February 21, 2013 Report Share Posted February 21, 2013 Probbably a snapped bead or your valve is getting in the way Quote Link to comment Share on other sites More sharing options...
rosslittledubber Posted February 21, 2013 Author Report Share Posted February 21, 2013 Bead is all fine and rim is fine aswell, its weird, just start to ride away and tyre starts peeling off the rim... Quote Link to comment Share on other sites More sharing options...
customrider-Rhys Posted February 21, 2013 Report Share Posted February 21, 2013 i had this, new tyre new rim, i got an old thick inner tube, cut a section out and rapped it round my rim like a second rim tape, never had a problem since, worked a treat, makes it harder to get the tyre on and off though Quote Link to comment Share on other sites More sharing options...
rosslittledubber Posted February 21, 2013 Author Report Share Posted February 21, 2013 Yeah i snapped my valve the other day and put a new tube in so disturbed the bead, done two days of riding since and this evening its just been a nightmare!! I might try the tube trick.. Failing that im thinking bead sealer like you use on car alloys when they are corroded.. Its like a glue that will help to hold it on :/ Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted February 21, 2013 Report Share Posted February 21, 2013 Bead sealer wont work as it is used to fill in the small gaps from corrosion to get a better seal on the tyre. It's not a glue... Quote Link to comment Share on other sites More sharing options...
rosslittledubber Posted February 22, 2013 Author Report Share Posted February 22, 2013 The old style black stuff dries pretty hard, worked in a few garages and used it on stretched car tyres to help stop them popping off, also on a few motorbike tyres.. Is a long shot with a pushbike tyre but surely will have nothing to lose :/ Quote Link to comment Share on other sites More sharing options...
AkuskaUK Posted February 22, 2013 Report Share Posted February 22, 2013 This happened to me, I have a flatspot on my rim. It took a day of pumping it up half way, riding it up and down my garden slowly, then pumping it a bit more. It's been good ever since! Quote Link to comment Share on other sites More sharing options...
trialsiain Posted February 22, 2013 Report Share Posted February 22, 2013 Lift your bike off the ground when your pumping up the tyre this happened to me before Quote Link to comment Share on other sites More sharing options...
rosslittledubber Posted February 22, 2013 Author Report Share Posted February 22, 2013 Bike is off the ground when i pump up the tyre... Think im going to try a new back wheel when i get some cash to be honest Quote Link to comment Share on other sites More sharing options...
