ashleys sugden Posted February 14, 2013 Report Share Posted February 14, 2013 its getting annoying now, both wheels on my echo. they just keep going and going. any reason for this? or are they just built up shit? i have no idea and its annoying! please help Quote Link to comment Share on other sites More sharing options...
N.Wood Posted February 14, 2013 Report Share Posted February 14, 2013 They will just keep on going until you get the wheels re-built. The spokes get old, lose their flex, snap, you replace it and it moves around to the next weakest and so on. Minus whale re-build both wheels and call it a day. Quote Link to comment Share on other sites More sharing options...
ashleys sugden Posted February 14, 2013 Author Report Share Posted February 14, 2013 is it easy to rebuild wheels? i can true them up well but ive never had to build one up Quote Link to comment Share on other sites More sharing options...
N.Wood Posted February 14, 2013 Report Share Posted February 14, 2013 Sure, there are lots of good guides on the interwebs. I used Mark W's when I first stated, thats on here somewhere lemme find a link. EDIT: http://www.trials-forum.co.uk/topic/80777-how-to-build-a-wheel/ There she blows. 1 Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted February 14, 2013 Report Share Posted February 14, 2013 Do you keep truing the wheel ? Quote Link to comment Share on other sites More sharing options...
Danny00135 Posted February 14, 2013 Report Share Posted February 14, 2013 is it easy to rebuild wheels? i can true them up well but ive never had to build one up Trueing is the hardest part of building a wheel.. It's actually really easy when you get the hang of it Quote Link to comment Share on other sites More sharing options...
Blake Posted February 14, 2013 Report Share Posted February 14, 2013 Did you buy a full build echo? could be wank spokes. Get some ace ones, building isn't that hard at all Quote Link to comment Share on other sites More sharing options...
Jake. Posted February 15, 2013 Report Share Posted February 15, 2013 Built my own wheels for the limey 4 just cause I wanted black spokes, takes a bit of time and if you make a mistake you'll have to debuild and re-build it again. I took my wheels to the local bike shop before truing it up completely just to make sure it was all good and they said it was good for a first ever wheelbuild. It's a nice feeling using wheels you built. Quote Link to comment Share on other sites More sharing options...
ashleys sugden Posted February 15, 2013 Author Report Share Posted February 15, 2013 Do you keep truing the wheel ? i do when the spokes snap.. Trueing is the hardest part of building a wheel.. It's actually really easy when you get the hang of it ok thanks, i might have to try on an old wheel first. Did you buy a full build echo? could be wank spokes. Get some ace ones, building isn't that hard at all yeah they are a standard build, and the front wheels spokes are laced up weird, the disc side cross each other but the other side dont? Built my own wheels for the limey 4 just cause I wanted black spokes, takes a bit of time and if you make a mistake you'll have to debuild and re-build it again. I took my wheels to the local bike shop before truing it up completely just to make sure it was all good and they said it was good for a first ever wheelbuild. It's a nice feeling using wheels you built. i will have to try, ill just have to get a whole new load of spokes, i will probably do it at the end of these holidays.. just replace the ones that have snapped for now, or on a wet day. thanks everyone Quote Link to comment Share on other sites More sharing options...
Blake Posted February 15, 2013 Report Share Posted February 15, 2013 Pretty common for wheels to have 2x or 3x one side then radial the other But yeah, I'd reccomend some more heavy duty spokes off tarty, should resolve your problem Quote Link to comment Share on other sites More sharing options...
ashleys sugden Posted February 15, 2013 Author Report Share Posted February 15, 2013 Pretty common for wheels to have 2x or 3x one side then radial the other But yeah, I'd reccomend some more heavy duty spokes off tarty, should resolve your problem ok thanks, i will probably do it at the end of next week sometime and just replace them for now. thanks Quote Link to comment Share on other sites More sharing options...
albert_03 Posted February 15, 2013 Report Share Posted February 15, 2013 Truing your wheels is only part of the story. High,UNIFORM spoke tension is key to making a strong wheel, and as a bonus it will stay true longer. Quote Link to comment Share on other sites More sharing options...
Rich J Posted February 15, 2013 Report Share Posted February 15, 2013 Why are there references to whales in this topic? Quote Link to comment Share on other sites More sharing options...
ashleys sugden Posted February 15, 2013 Author Report Share Posted February 15, 2013 the bike shop has given me some spacer protector things to put on the end of the spokes to help keep them strong. i rode for 3 hours tonight and they are still fine. Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted February 15, 2013 Report Share Posted February 15, 2013 Spacer protector thingies? Quote Link to comment Share on other sites More sharing options...
customrider-Rhys Posted February 15, 2013 Report Share Posted February 15, 2013 Spacer protector thingies? could it be spoke washers? the ones that go on the spoke heads at the hub. 1 Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted February 15, 2013 Report Share Posted February 15, 2013 (edited) i dont know if that relly solves the problem or just gives the spokes time to bed into the washer and then break... those washers are for new builds in certain circumstances,not a repair thing Edited February 15, 2013 by FamilyBiker Quote Link to comment Share on other sites More sharing options...
ashleys sugden Posted February 16, 2013 Author Report Share Posted February 16, 2013 could it be spoke washers? the ones that go on the spoke heads at the hub. thats what they are.. they said the disc tabs can be worn on the inside which causes the spokes to snap. Quote Link to comment Share on other sites More sharing options...
jigga Posted February 16, 2013 Report Share Posted February 16, 2013 I had the same problem with Echo spokes on my Echo urban 24". Spokes seemed shit quality. I also found when the wheel was put in a proper wheel jig the rim wasnt made even. When the wheel sat in the jig, one edge or side sat higher than the other. which meant when i was landing on it, the slightly lower side was taking nore load initially, than the higher, hence breaking spokes every week. i'd already replaced the echo spokes with DT Swiss and the problem didnt go away. had to replace the rim. Quote Link to comment Share on other sites More sharing options...
