another caliper question
customrider-Rhys
Hello all, i need of a new caliper, thinking of buying a trialzone for the rear,
however on a well known site it says this 'Supplied with all fittings (including fitting bolts and shims for the #3 and #5 Caliper models), allowing easy fitting with any Hope Kevlar hose.'
so does this mean that i cant fit my hope braided hose to this? this may be a very stupid question, but i want to be sure.
thanks all
Edited by customrider-Rhys
  On 2/10/2013 at 9:03 PM, Cap said:
Would need a 6mm Stainless Shroud to fit the braided hose to it as i believe it is supplied with a 5mm stainless shroud :)
but does that apply if i have a hose already fitted up? i wouldn't look to changing and hose ends unless needed, so would my banjo fitting bolt strait on?
