Bleeding with a splitter.
BradJohnson
I'm going to put a splitter on my front brake.
Just wondering how i'd go about bleeding it using the conventional bucket bleed technique.
Would I leave one bleed screw in the slaves and do it as normal
or would I bleed one side put the bleed screw back in, and then do the other side.
Or would I leave both screws out bleed like normal and then put all the screws back in.
Or do I have it totally wrong :P
Help appreciated.
Okay.
Put the whole brake in the bath.
Undo both slave bleed bolts.
Undo lever bleed bolt.
Put finger over one slave hole and pump the lever, do the same for the other slave bleed hole and do up all the bolts underwater.
Pretty sure that should do the trick, it's basically bleeding it as usual but repeating the technique for both slaves.
