ooo Posted February 4, 2013 Report Share Posted February 4, 2013 I've turned the screw all the way in, but it doesn't move the lever, am I meant to see it poking out the topside of the lever ? I've unscrewed the grub and taken it out and it makes no difference... Or is the reach adjust, just nothing ? Quote Link to comment Share on other sites More sharing options...
Lewis Gething Posted February 4, 2013 Report Share Posted February 4, 2013 Screw the grub-screw in to move the lever blade closer to the bar. Then the grub-screw effectively just stops the lever from retracting fully once you've pulled it. Give it another go Quote Link to comment Share on other sites More sharing options...
ooo Posted February 4, 2013 Author Report Share Posted February 4, 2013 Screw the grub-screw in to move the lever blade closer to the bar. Then the grub-screw effectively just stops the lever from retracting fully once you've pulled it. Give it another go oh yeah did it with the lever squeezed, managed to get the grub screw through, must have been gunked up. Cheers mate Quote Link to comment Share on other sites More sharing options...
