OnzaComp2010Craig Posted February 3, 2013 Report Share Posted February 3, 2013 My freewheel skips everytime my back wheel goes lose is this something to worry bout ? Quote Link to comment Share on other sites More sharing options...
Jake. Posted February 3, 2013 Report Share Posted February 3, 2013 Yes 2 Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted February 3, 2013 Report Share Posted February 3, 2013 I've got a solution. Keep the wheel tight. 1 Quote Link to comment Share on other sites More sharing options...
OnzaComp2010Craig Posted February 3, 2013 Author Report Share Posted February 3, 2013 Won't keep tight Quote Link to comment Share on other sites More sharing options...
Kieran Morrison Posted February 3, 2013 Report Share Posted February 3, 2013 What do you mean? Quote Link to comment Share on other sites More sharing options...
OnzaComp2010Craig Posted February 3, 2013 Author Report Share Posted February 3, 2013 My back wheel is nearly f**ked everytime i tighten 1 hour later it will unlosen and then freewheel skips cuase it moves Quote Link to comment Share on other sites More sharing options...
Danny00135 Posted February 4, 2013 Report Share Posted February 4, 2013 My back wheel is nearly f**ked everytime i tighten 1 hour later it will unlosen and then freewheel skips cuase it moves Do you mean your wheel comes loose as in the bolts undo or the chain comes loose? Chain wise (going by your avatar) I thought onza comps had integrated tensioners? pretty impossible for your wheel to slip... More likely your chain is stretching bolt wise just slap some loctite threadlock on and it should solve your problem. Quote Link to comment Share on other sites More sharing options...
OnzaComp2010Craig Posted February 4, 2013 Author Report Share Posted February 4, 2013 well the chain is 2 days old thanks and they do Quote Link to comment Share on other sites More sharing options...
bing Posted February 4, 2013 Report Share Posted February 4, 2013 My back wheel is nearly f**ked everytime i tighten 1 hour later it will unlosen and then freewheel skips cuase it moves You my son, need a lesson in spelling, grammar and punctuation. It's a f**king nightmare reading your posts 3 Quote Link to comment Share on other sites More sharing options...
Danny00135 Posted February 4, 2013 Report Share Posted February 4, 2013 well the chain is 2 days old thanks and they do What chain? Chains tend to stretch a lot to start with then settle in.. You didn't answer my question however.. are the bolts un-screwing? If not chain stretch is your problem, should settle in soon Quote Link to comment Share on other sites More sharing options...
OnzaComp2010Craig Posted February 4, 2013 Author Report Share Posted February 4, 2013 Thanks, it stopped today ! its kmc cool chain no more skipping or that. Thanks alot! Quote Link to comment Share on other sites More sharing options...
