isitafox Posted February 2, 2013 Report Share Posted February 2, 2013 As the title says, will a 28h disc wheel be safe or am I at risk of destroying it from the stresses of using the disc? Quote Link to comment Share on other sites More sharing options...
Jake. Posted February 2, 2013 Report Share Posted February 2, 2013 It's about 12.5% weaker than a 32h. Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted February 2, 2013 Report Share Posted February 2, 2013 It´s ok. Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted February 2, 2013 Report Share Posted February 2, 2013 2-cross,3-cross? i´d go for 2 as the angle between spokes and nipples will be less weird. Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted February 2, 2013 Report Share Posted February 2, 2013 At least on the disc side I would go for 3x... Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted February 2, 2013 Report Share Posted February 2, 2013 (edited) imagine to have at least 12% more pulling force on the spokes when braking,then imagine the spokes beeing bent due to the angle the nipple would have with 3x. Edited February 2, 2013 by FamilyBiker Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted February 2, 2013 Report Share Posted February 2, 2013 I can imagine spokes beeing ripped out of the hub flange with 2x crossed spokes. Quote Link to comment Share on other sites More sharing options...
isitafox Posted February 2, 2013 Author Report Share Posted February 2, 2013 Thanks guys you've answered my question. I'll give 28h a miss! Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted February 2, 2013 Report Share Posted February 2, 2013 (edited) I can imagine spokes beeing ripped out of the hub flange with 2x crossed spokes. !!! ... ??? i can imagine spokes changing their angle to the hub and nipples ,when the hub is stopped and the rest of the wheel is trying to continue rotating because its under load. hence a 2 cross would come near to a tangential angle when braking,in 3cross spokes would end in an angle over tangential,beeing bent due to that,not pulled only. in this i assume you got a hub flange over 45mm diameter and a rim under 510mm e.r.d.(most 24 inch dirt,street,trials combos except the ones with assymetrical flanges???) isitafox,give it a try,dt has 28 disc enduro wheels and they work. Edited February 2, 2013 by FamilyBiker Quote Link to comment Share on other sites More sharing options...
