Help I'm new and having serious problems.
paul_stuart
Did the 1st step and bought a bike ( diamondback tekkiya)
Unfortunately I got ripped off .
I believe the bottom bracket is to blame as both cranks are wobbling side to side with each other . What do I replace it with (cheap as possible . Make model and link if poss . )
Also the previous owner has taken away the gears and has just put a single speed chain on the cog :( happy with a single speed bike but surely I don't just leave it like this ??
I've just started and already I'm regretting it . Please if u can help me .
Thanks very much
i think you will need a single speed cog and spacer kit it will help out with weight on the rear wheel as i am asuming they have just removed the gear shifter and mech and cut the chain and kept the rear cogs with the full 8 spd cassette
it may just need tightening up. try tightening the crank bolts first; see if it persists, then you know its your BB, if your new to bikes in general take it to a local bike shop, pay them to look/sort it. but ask if they'll show you how/what they do so you'll know in the future...
  • Like 1
