FamilyBiker Posted February 7, 2013 Report Share Posted February 7, 2013 (edited) as the pivot points seem to be the same distance i think so. could mr.drummond measure that for us? would be much appreciated. Edited February 7, 2013 by FamilyBiker Quote Link to comment Share on other sites More sharing options...
Mr Curve Posted February 7, 2013 Report Share Posted February 7, 2013 Great to see another choice of lever body on the market for those who liked the 05 style. The 3 finger lever blade seems interesting as its meeting in the middle compared to other lever blades such as 2 n 4 finger blades. As for performance lets see how it compares. Quote Link to comment Share on other sites More sharing options...
LiamWood! Posted February 7, 2013 Report Share Posted February 7, 2013 If a deng blade fits, I'd be quite interested. Quote Link to comment Share on other sites More sharing options...
Drummond Posted February 7, 2013 Report Share Posted February 7, 2013 as the pivot points seem to be the same distance i think so. could mr.drummond measure that for us? would be much appreciated. Just tried to fit a maggie 05 lever blade to the tensile body... All the dimensions match up perfectly so any cnc'd lever that fits an 05 maggie should fit the Tensile too... However the pivot bolt is fatter on the Tensile lever so the pivot hole on the lever blade is also bigger, any after market blades would need either the pivot hole drilled out or a nifty replacement bolt/shim set up... Hope that makes sense... 1 Quote Link to comment Share on other sites More sharing options...
Jake. Posted February 7, 2013 Report Share Posted February 7, 2013 (edited) So basically the bolt that holds the lever in place is bigger on the tensile one, and in order to use a different lever you'd have to drill the pivot hole on the lever so it matches the tensile pivot bolt hole? Sounds quite easy to do if someone is really desperate to have a different lever. Edit: are you allowed to show a picture of your setup? Curious to see what it looks like on a bike. Edited February 7, 2013 by JMCD Quote Link to comment Share on other sites More sharing options...
customrider-Rhys Posted March 19, 2013 Report Share Posted March 19, 2013 when are these going to be sold? i need one Quote Link to comment Share on other sites More sharing options...
Jake. Posted March 19, 2013 Report Share Posted March 19, 2013 Was thinking that too Quote Link to comment Share on other sites More sharing options...
trialsiain Posted March 19, 2013 Report Share Posted March 19, 2013 April 1 Quote Link to comment Share on other sites More sharing options...
dngr2self Posted May 30, 2013 Report Share Posted May 30, 2013 What's going on with these levers? Are they for sale yet? Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted May 30, 2013 Report Share Posted May 30, 2013 (edited) i´ve nearly given up on them,its half a year since they were mentioned first. Edited May 30, 2013 by FamilyBiker Quote Link to comment Share on other sites More sharing options...
dngr2self Posted May 30, 2013 Report Share Posted May 30, 2013 I know I've been after one since I first saw them. Quote Link to comment Share on other sites More sharing options...
J.KYDD Posted May 30, 2013 Report Share Posted May 30, 2013 From speaking to Seddon, the prototypes they were sent were really good but the first set of production ones which came through after that had issues. This has delayed things pretty badly 1 Quote Link to comment Share on other sites More sharing options...
Jake. Posted May 30, 2013 Report Share Posted May 30, 2013 I waited 3 months for them but gave in and bought some 04s. Shame really. Quote Link to comment Share on other sites More sharing options...
niconj Posted December 20, 2013 Report Share Posted December 20, 2013 Has anyone experienced this? No air inside and a new lever. Nico. Quote Link to comment Share on other sites More sharing options...
isitafox Posted December 20, 2013 Report Share Posted December 20, 2013 What's it bled with? Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted December 20, 2013 Report Share Posted December 20, 2013 It does actually have a little air in - the 'free' stroke at the start when you took all the TPA off indicates this. 1 Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted December 20, 2013 Report Share Posted December 20, 2013 i think the piston isnt moving all the way out after releasing the lever,seeing that vid. i mean,even a lever that has air inside should come out again completely because theres a spring behind it Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted December 20, 2013 Report Share Posted December 20, 2013 mean,even a lever that has air inside should come out again completely because theres a spring behind it But if the system isn't full of brake fluid it will be attempting to pull a vacuum, which holds the piston in. Quote Link to comment Share on other sites More sharing options...
J.KYDD Posted December 20, 2013 Report Share Posted December 20, 2013 Looks like you've bled it with the TPA already screwed in a bit. Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted December 20, 2013 Report Share Posted December 20, 2013 i am pretty aware of the fact this can happen,but also havent seen it except for swollen pistons or pistons with dual seal rings. anybody knows if the toccos piston got 2 seal rings? Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted December 20, 2013 Report Share Posted December 20, 2013 Yep, the lip seal is much more beefy than standard too. Quote Link to comment Share on other sites More sharing options...
chris H Posted December 20, 2013 Report Share Posted December 20, 2013 Sorry to jump in, grease the piston and that will help, aswel as the fresh bleed getting rid of the air. Adds, will you be putting more pictures up of the tensile? Would love to see all the components. 1 Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted December 20, 2013 Report Share Posted December 20, 2013 please make some kind of exploded view pic Quote Link to comment Share on other sites More sharing options...
Mark W Posted December 20, 2013 Report Share Posted December 20, 2013 5 Quote Link to comment Share on other sites More sharing options...
Blake Posted December 20, 2013 Report Share Posted December 20, 2013 hahahah wow Quote Link to comment Share on other sites More sharing options...
